 Post subject: DART OR MOTOWN BLOCK
 Post Posted: Fri Jan 11, 2013 1:41 pm
What is the going price for these 2 blocks? which one is better?
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post subject: Re: DART OR MOTOWN BLOCK
 Post Posted: Fri Jan 11, 2013 4:28 pm
Dart Block is better. Depends on which block you want. There are a lot of options.
Base Little M is about 2000 but then machine work is still required with all blocks.
My block Little M Pro Series was 3000 has 5 billet caps, but standard deck height and standard pan rail.
 Post Posted: Fri Jan 11, 2013 10:40 pm
I have used both, no issue with either, but I would buy Dart in the future over World. Machine work was spot on.
 Post Posted: Sat Jan 12, 2013 5:53 am
Go with the Dart block. I had an older Motwn block that I split the main webbing out of. Yes I was making 800Hp with 3.875 stroke,but I had the bypass in my fuel pump stick shut and it flooded my engine. I do not think that helped it. I went with a little M from Dart as a replacement. Better looking block from Dart. Bob J
 Post Posted: Sun Jan 13, 2013 7:37 am
Dart
551D Super Pro - 8.51 @ 158
-- Albert Einstein
