Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post Posted: Sun Oct 21, 2012 11:11 am
I was using a pair of the gaskets that Mark showed in my carb this year. I did have to enlarge the dowel holes just a bit, as they were off on my stuff, but that was it. I like them. they didn't leak, stick or anything else like that, and I had them off plenty!!! No permanent indentions either. I can't say for sure if they ever made a difference in the calibration, as the gaskets that I had on it before were swollen quite a bit and seems like they partially blocked some of the passages, but that wasn't an issue with those. I'm going to get another set for my other carb and a spare set in case I do something stupid...........The nice thing is they last.......buy them once and that's it...
Mark Goulette
 Post Posted: Sun Oct 21, 2012 1:30 pm
Pics!
Standard 2 circuit block
QFT 3 hole block w/ vacuum provision
BLP and QFT block comparison. Look how low the BLP idle crossover passage is.
BLP 5 hole block. See how close the hole in gasket is.
4500 mainbody. In oldstyle 750 Dominators the bottom of this cavity is drilled for timed vacuum. Works well at vacuum. As engine speed increases vacuum sucks gasket back and opens bowl to manifold vacuum. Instant 5th jet. NonHP 4150 carbs may also have this problem.
Hp type carb has no drilled passage.
Solutions are:
A. fill 4500 cavity with epoxy if required.
B. use only BLP or QFT gaskets.
 Post Posted: Sun Oct 21, 2012 2:13 pm
Bruce Is this hole okay if you are using it for vacuum?
74 Firebird 3580 lbs
 Post Posted: Sun Oct 21, 2012 2:34 pm
Great post Bruce!!!!!! Thanks for spending the time to point it all out!!!!!!!!! \:D/
Ken, This needs to be a sticky IMO
 Post Posted: Sun Oct 21, 2012 3:02 pm
firebird, my eyes can't see that very well. Can you post a clearer photo?
 Post Posted: Sun Oct 21, 2012 3:06 pm
Bruce my 7320 & 9377 has that vacuum cavity but there is no hole to the throttle plate..
 Post Posted: Sun Oct 21, 2012 3:41 pm
Bruce I took that pic a couple of weeks back with my phone, The guy that did my 750 dom that he made a 1050, turned around the main body putting that big vac port in back so i could use for brakes etc, and then drilled another hole in what used to be the back connecting the two holes that went into the throttle bore so i could have vac advance. It works perfectly, the only thing He forgot to do was plug that original front hole that was now in back, cause when i first got the carb it would drain the back bowl, and i couldn't figure out why til i told him about it. I then just used jb weld to cover that rear hole and no more issues with it.
 Post Posted: Sun Oct 21, 2012 4:11 pm
I had the same problem when my engine was new. Now i have cyls 3 and 4 showing 12% leakage. Probably been like that since the beginning.
 Post Posted: Wed Nov 14, 2012 5:49 pm
Guy's, I don't know how you feel about this, but I have been putting a very thin layer of chap-stick on all of my metering plate gaskets for years. Weather they are non stick or not. On the advise of the owner of are local hot rod shop. He is very sharp and raced for years. I never have a problem. Even years later I have reused gaskets sometimes in other carbs. Once I skipped the chap-stick and the non-stick gasket tore into separate peaces. Don't know much about the clear gaskets.
Question: on some of my plate gaskets the rectangle opening coming from the vent tube is partially blocked at one corner. What is the reason for this? Restrict the air coming in?
Also I know most of you do not use power valves ,or just on one side, but have you see the power valves that come in the Quick fuel rebuild kit. They have four rectangle openings instead of two. Is this any kind of advantage to this?
Just Primer
 Post Posted: Wed Nov 14, 2012 6:40 pm
Just Primer
Those are what is known as "High Flow" power valves and that's what we normally use on the primary side "IF" we run a PV that is.
 Post Posted: Wed Nov 14, 2012 8:34 pm
I have always use the Holley "high flow". They only have two rectangle ports and they are not as tall (in the opening). I normally run 4.5 but these are 6.5.
Users browsing this forum: Bing [Bot] and 5 guests
