Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Filter
 Post Posted: Fri Oct 12, 2012 11:05 am
So we need a finer filter mesh??
 Post Posted: Fri Oct 12, 2012 12:12 pm
I found a old BG catalog and it lists the 5000 filter at 8 microns, so yes.
 Post Posted: Fri Oct 12, 2012 4:40 pm
wow 8 microns...Wondering if I could make a somewhat of a filter with using new mesh on an old filter..
 Post Posted: Fri Oct 12, 2012 7:32 pm
8 microns = 0.00031496063in O:)
 Post Posted: Fri Oct 12, 2012 8:39 pm
Talk to me Ken??? What is used for alky??
 Post Posted: Sat Oct 13, 2012 12:04 am
I already told you what I use on the pump discharge on the dragster?
http://www.ebay.com/itm/New-Kinsler-AN6 ... a0&vxp=mtr
And I strain the fuel going into the cell. That's it! Not sure what the micron rating is on my Kinsler filter but according to that website it's not very fine @ 140 micron? :-k Just remember that the smaller the micron rating, the larger the filter area has to be to be able to flow enough fuel.
Oh, and BTW, I've got a large BG filter on the suction line on the Studebaker that's -10 and about 10" long so it "may" be one of them 5 micron mofo's. Bought that thing so long ago I can't remember exactly what it was. Of course half the time I can't tell you what I had for dinner the night before either.
Having said all that, I'd be looking at that $33 one at 80 microns and see how it works. :-k
 Post Posted: Sat Oct 13, 2012 6:32 am
OK they also have one that is a bit larger and has 12an ends on it so I may go there as I have some 12 an line and ends so I just need a fuel cell fitting...Thanks guys...
 Post Posted: Mon Oct 15, 2012 12:00 pm
Barry, I think i found elements to work in our BG filters and they look the same. Canton Racing Products said they have elements of 1 or 8 microns that are capatable with gas, meth and nitro. The dimentions for these elements are very close to BG's. Cantons element size L- 2.625 ID-1.125 OD- 2.000. The old BG element i have here, measures L-2.725, ID-1.130, OD-2.035, other than length it should fit, maybe a larger diameter o-ring for the crush seal at each end of the element. The parts # 26-600= 1 micron and # 26-602= 8 microns. Sold at Jegs $ 10.55 and Summit $ 10.75. Will be calling Summit to order one after i drain the fuel system this week end.
 Post Posted: Mon Oct 15, 2012 2:02 pm
Sounds good Ron...Let me know how you make out with that as I have not done anything yet...
Have a couple more weekends to go it the weather holds out...
 Post Posted: Sun Nov 11, 2012 9:35 am
Anything new here with the filter Ron???
 Post Posted: Tue Nov 13, 2012 2:43 am
Barry the Canton element # 26-602-8 micron fit my BG 5000 filter, about 3 years ago BG changed their elements, the new elements were longer so i had to machine one of the end cap to fit the longer element. This Canton element is a little shorter like the original BG, but it still fits well. I bought the 8 micron element which is the same # micron as the BG ones, and they also have a 1 micron avalable. Sold at Summit or Jegs.
 Post Posted: Tue Nov 13, 2012 11:55 am
Ron I have the updated newer BG 5000 filter..Have to look for the size difference.
Users browsing this forum: Google [Bot] and 0 guests
