Author |
Message |
Ron Gusack
Posted: Mon Jun 04, 2012 3:12 pm |
Joined: Fri Feb 17, 2012 8:09 pm Posts: 166 Location: Maryland
I bought an Earls fuel shut off 1/2 npt ball valve from Summit for 35.95. When I got I was surprised to see how restricted it was. So I went to Lowes and got one for 16 with a much bigger hole for the fuel to pass through. As long as the seals are teflon, you shouldn't have any leak problems. McMaster has some for about 9 bucks, but I had no way of knowing how restricted they were. http://www.lowes.com/pd_331187-61002-70 ... 2%2Bnpt%2B
Beretta
Posted: Mon Jun 04, 2012 5:50 pm |
Ron I had one like that for years on my Vega and never had an issue with it...
nomad
Posted: Sun Jun 17, 2012 1:19 pm |
Joined: Thu Jan 29, 2009 10:59 am Posts: 438 Location: Auburndale, Florida
This may be a big one or not. I'll post a photo when I can. The Super Flow 901 dyno we use had a fuel pump seal fail. It's a Magna Flow even though it says Super Flow.
Couldn't find a seal and a fellow general service shop owner provided us with a seal from a Chrysler transmission that was a perfect fit. Says he uses these to repair these pumps all the time, and they last a long time too. Wonder if it fits the BG 400 pump.
I'll post the exact details ASAP.
nomad
Posted: Wed Jun 20, 2012 5:27 pm |
Okay, here's the deal on the MaganFuel pump seal.
So what my pal tells me. It's the kick down seal for a Chrysler transmission. They come in the rebuild kits for these transmissions. Most rebuilders don't use them because the opening is above the fluid level. So to those guys they're a throwaway item. Also, they don't seem to be serviced separately. You need the kit to get the seal.
Maybe your local trans rebuilder has some hanging around.
Beretta
Posted: Wed Jun 20, 2012 5:33 pm |
torque flight ???
wrightway
Posted: Wed Jun 20, 2012 9:57 pm |
Joined: Fri Mar 06, 2009 9:24 pm Posts: 15 Location: lawton, MI
Its not quite the same but i have seen a power door lock solenoid used as a 1-2 shift solenoid on a pro stick shifter
_________________ Joe Wright
nomad
Posted: Thu Jun 21, 2012 10:03 pm |
Beretta wrote: torque flight ??? Yup.
cuslog
Posted: Tue Jul 17, 2012 9:05 am |
X2 on the AVGas ! I've been running it for a couple years now in my blown (10 lbs boost) 540 and I like it. I think its a high quality fuel. Up here in Canada I was paying ~$700 / drum for race gas, AVGas is ~$350 / drum.
Ken0069
Posted: Tue Jul 17, 2012 10:30 am |
Site Admin |
Joined: Tue Apr 18, 2006 6:38 am Posts: 11807 Location: Coming At Ya!
cuslog wrote: X2 on the AVGas ! I've been running it for a couple years now in my blown (10 lbs boost) 540 and I like it. I think its a high quality fuel. Up here in Canada I was paying ~$700 / drum for race gas, AVGas is ~$350 / drum. And E85 is CHEAPER and BETTER than AVGas!! I know of ppl running 15 to 1 compression that are running E85. Don't know if it's available there in CA but it might be worth a look.
cuslog
Posted: Tue Jul 17, 2012 12:45 pm |
Ken0069 wrote: And E85 is CHEAPER and BETTER than AVGas!! I know of ppl running 15 to 1 compression that are running E85. Don't know if it's available there in CA but it might be worth a look.  Hmmmmmmm, haven't noticed, but then, I don't get out much  , normally fill up at a cardlock. I've seen notices like "may contain up to 5 or 10 % Methanol" but never noticed "E85". So, is E85 = 85% methanol or 15% methanol ?
cuslog
Posted: Tue Jul 17, 2012 12:55 pm |
OK, answered my own question: 85% Ethanol. So does that mean on my blown 540 the tech guy would want to see blower restraints if I'm on E85 ? Bigger fuel pump ? Same between races maintenance as methanol ?
Ken0069
Posted: Tue Jul 17, 2012 2:07 pm |
Site Admin |
cuslog wrote: OK, answered my own question: 85% Ethanol. So does that mean on my blown 540 the tech guy would want to see blower restraints if I'm on E85 ? Bigger fuel pump ? Same between races maintenance as methanol ? Don't know about the blower restraints but most guys run the same fuel pump, assuming of course that you have a good quality high volume pump like a Magnifuel or Aeromotive to begin with. I know a guy that ran methanol with a BG-400 pump with a 496 BBC a few years back. Also not sure what you mean about "maintenance" as the only thing I do with methanol that I don't do with gas is I drain the carb fuel bowls between races and that's about it. Those nytrophil floats are $125 a set so I do take care of those!! I do an oil change every season or two whether it needs it or not cuz methanol carbs don't typically milk the oil up. I do run $12 a quart 20w 50 Mobile 1 V Twin oil though. FYI, Beretta just bought E85 up in Jersey for like $3.30 a gallon and I do believe he said that the price had dropped to $2.90 a week or two later. Sounds good doesn't it?
cuslog
Posted: Tue Jul 17, 2012 2:51 pm |
Google searched for "E85 BC Canada" ....... says only 3 E85 stations in Canada, all in Ontario +- 2,000 miles from me. So, I guess I won't be burning E85 anytime soon.
Ken0069
Posted: Tue Jul 17, 2012 6:32 pm |
Site Admin |
cuslog wrote: Google searched for "E85 BC Canada" ....... says only 3 E85 stations in Canada, all in Ontario +- 2,000 miles from me. So, I guess I won't be burning E85 anytime soon.  Sounds like you and I have the same problem as the nearest supply for me is 70 miles away in Charlottesville, Va. I just recently bought a drum of methanol @ $200 so it's borderline for me by the time I drive 140+ miles to get it. I do keep that thought in the back of my mind though and one day it just might happen.
ADAMSVEGA
Posted: Thu Sep 13, 2012 6:05 am |
DOLLAR STORE .....alum drink bottle for puke tanks  s/s scrubby for oil seperators .breather  pipe clamp to mount anything to roll bars
