Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 1250 E conversion
 Post Posted: Tue Jun 05, 2012 1:26 pm
.136 is fine for a 1050 but not a 1250, I'd start at least .160. Go up from there to start. You will see a MPH improvement when you go in the right direction.
 Post Posted: Tue Jun 05, 2012 5:00 pm
Mark are the rest of the spec's good??? Bruce listed them on the 1st page.
Thanks
 Post Posted: Tue Jun 05, 2012 5:03 pm
How about timing? :-k
 Post Posted: Tue Jun 05, 2012 5:07 pm
running 36 now with gas..
 Post Posted: Tue Jun 05, 2012 5:24 pm
Everything else is OK to start, you might plug the .026 bottom e-bleeds and then get an AFR reading to go from there.
 Post Posted: Tue Jun 05, 2012 5:41 pm
I have the bottom plugged
.020
plugged
.020
.024
plugged
 Post Posted: Tue Jun 05, 2012 8:33 pm
Plug the .024 as well, a trend I saw on my last logs will have me making a similar change, of course that will be a while now.
 Post Posted: Tue Jun 05, 2012 9:07 pm
Well, you could put either Bruce or your brother in that thing and continue testing?? ;-)
 Post Posted: Tue Jun 05, 2012 9:23 pm
Mark first off, Welcome back. Glad you are doing well and things turned out good for you.
Secondly what did you see in the log that is having you block the other bleed off? I only run 2 emulsion bleeds in the carbs I do from 024 - 028 depending on engine setup. On the dominators I run .024 - Blank - .024 - Blank - Blank on the 5 emulsion blocks. With the 4 emulsion blocks I do .024-Blank -.024-Blank. This is the best I have found so far. Didnt do the extensive testing that you and Bruce did but moved them around a bit. I was going to try a setup a little like yours next week to see how it changes things.
 Post Posted: Tue Jun 05, 2012 9:25 pm
I've been told not to strap in for a while. The belt goes over my incisions. Plus, I haven't cross licensed for over 125 inches.
Barry's the new testee for a while. We're gonna use his fuel, kinda long distance. I'm looking for a 170 MPH pass on hootch. =D>
Meanwhile, I have some Innovate stuff to install.
 Post Posted: Tue Jun 05, 2012 10:53 pm
I bet you'll be ready before Mark will though.
License? For what? Image
 Post Posted: Wed Jun 06, 2012 5:06 am
Ken Bruce is in NHRA land and need a cross license for to run a digger..Yep 3 test passes and the
send NHRA the check :- ...Yep the faster you go the more $$$$ you send them....
 Post Posted: Wed Jun 06, 2012 5:08 am
So do you want me to plug the .024 now before I test or leave it and see what happens...??
 Post Posted: Wed Jun 06, 2012 7:10 am
NHRA land. =; I love it.
 Post Posted: Wed Jun 06, 2012 8:09 am
Yes, plug it first. On the 1250 I saw a lean trend up top I didn't see on the 1050 with the same setup. .020, plug, .020, plug plug.
I am working on getting someone I trust to drive it a few times, but i need to build some stamina and have my incisions heal before I'm up to being crew.
