 Post subject: Newbie here
 Post Posted: Fri Jun 01, 2012 3:19 am
Hi my name is Steve. Have been dragracing since the 90's, have been reading lots of post here
and it has been very informative. My current ride is backhalfed oz car with n/a 23deg sb.
I heard about Mark Whitener on another site hope he gets better soon, that guy is very knowlegable.
Thanks.
 Post subject: Re: Newbie here
 Post Posted: Fri Jun 01, 2012 5:09 am
Hey Steve and welcome!!!!!!!!!! Post some pictures down in "Show your stuff" section..
What are you working on??
 Post Posted: Fri Jun 01, 2012 6:17 am
 Post Posted: Fri Jun 01, 2012 7:15 am
Nothing like a wheels up picture \:D/ \:D/
 Post Posted: Fri Jun 01, 2012 7:52 am
Welcome to the Board Steve \:D/ \:D/ \:D/ \:D/
 Post Posted: Fri Jun 01, 2012 10:24 am
Ah yes, another of them "Oz" cars with the driver on the WRONG side?? =;
Welcome again Steve! ;-)
 Post Posted: Fri Jun 01, 2012 11:19 am
Funny but thought the driver of those car are on the "right" side ;-)
 Post Posted: Fri Jun 01, 2012 7:44 pm
The Oz cars are correctly designed, the US ones are not. Think about this, the problem is right rear unloading so why would you want to place the driver on the left? If your going to build a car with offset center of gravity then placing the driver on the right hand side reduces the need to weight jack the right rear, thus you finish up with a more even fourlink configuration side to side.
 Post Posted: Fri Jun 01, 2012 7:48 pm
Thank Guys, as you can see in my pic my hoosiers are wadding a bit I run 7.5 might try 10.
I think tire is taking the job of the shock.
Do you guys use anti roll bars or stop body roll through stiffer rear compression?
As for drivers side seating we are right..... =; =;
Steve...
 Post Posted: Fri Jun 01, 2012 8:00 pm
Use an anti roll bar. I've made some for racers, use 3" hydraulic tubing mounted in bearings. They dont flex and go faster. Zero flex is the aim so why install a stupid little one like most people do. Just do overkill and it has to work. I get people to make an accurate wire model of their chassis, then they start flexing it and playing with chassis bar locations. Its the cheapest and best way for a racer to see flex and chassis problems. Its real world engineering thats better than stress analysis in my book. Make a model about 400mm long is usually a good start and use welding wire. Solder the joints with a soldering iron then its easy to break and redo etc. You will be very surprised if you make one at what you will learn. The reason for making a model is to improve the chassis rigidity because it has to be rigid from the from the engine to the rear axle and if you install a anti roll bar and the chassis is butter then there is no gain.
 Post Posted: Fri Jun 01, 2012 8:23 pm
shrinker wrote:
The Oz cars are correctly designed, the US ones are not. .
what no bites on that jibe yet? Ken must be slippin' =;
 Post Posted: Fri Jun 01, 2012 8:48 pm
Hey, I wouldn't expect anything different from someone that lives their entire life upside down. ;-)
And along that line, I've always wondered why boats here in the "States" are right side drive when cars etc are on the left?? :-k
 Post Posted: Fri Jun 01, 2012 9:08 pm
Yeah thats a good one Ken.
Well the race boats here have the driver on the left. :-k General boats have the driver on the right.
All I can say is the US is :-# up. Now Im sure you will agree with that but probably on a different subject line.
We might be upside down but at least we can think clearly with all the blood rush.
