 Post subject: Freshening up the 522
 Post Posted: Sat Feb 11, 2012 3:20 pm
Having sold my good 540 I need to freshen up the 522. The 540 was an alcohol engine, the 522 ran on C14. I have spent a lot of money on the alky changeover and would like to use it in the 522. Do I need to change the cam for the switch over? The current cam is .765/.731, 282/292 @ .050", 110 lobe center and is a 7/4 swap. Is there anything else I should be worrying about?
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Wed Feb 29, 2012 5:58 am
I don't know abou the cam but would think it would be fine..I know Curtis said something about a cam change with big motors with regards to duration..
Do you have a carb or injection??
 Post Posted: Thu Mar 01, 2012 5:43 am
I have gone to a a Rons Terminator. I was just wondering if there were changes I was definately going to need to make because of th alcohol.
-- Albert Einstein
 Post Posted: Thu Mar 01, 2012 9:05 am
With that mechaical injection, you'll need to buy LOTS of oil for oil changes you'll need after each race. ;-)
You'll also want to pull that pan 2 or 3 times a season to clean the sludge out of the bottom of the pan.
 Post Posted: Thu Mar 01, 2012 5:16 pm
That cam sounds huge. What will it idle like. Wouldn't you need a vac pump for the brakes to work at idle?
 Post Posted: Thu Mar 01, 2012 6:04 pm
O:) Image Your'e kidding, right? :-k
 Post Posted: Thu Mar 01, 2012 7:27 pm
Have to remember that most of the cars here are drag cars only so no power brakes in fact no power anything....... O:)
 Post Posted: Thu Mar 01, 2012 8:51 pm
Thanks. I needed a good chuckle. You can see a picture of my car in my avatar. No power brakes but yes it does have a vacuum pump.
-- Albert Einstein
