Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Changes
 Post Posted: Tue Feb 07, 2012 5:57 am
#-o I think I would want it to sit a bit lower and control the wheelie and bounce with a stop..
Thinking your going to need lighter springs.
 Post Posted: Tue Feb 07, 2012 8:49 am
These are the lightest springs. The will settle over time.If I get a chance I'll post pictures tonight. It willbe at stock ride height or a little less due to the design of the control arms.
 Post Posted: Tue Feb 07, 2012 8:34 pm
Maybe after 6 years of being tied down it will set that low again. ;-)
 Post Posted: Wed Feb 08, 2012 6:07 am
The height the way it was I think is where you want it...IMO you don't want the nose up going down the track as it is going to slow you down...Nose down is better... =;
 Post Posted: Wed Feb 08, 2012 10:02 am
I will give it time to settle. The pictures are from the first night on the wheels. I think after we tie it down some it will lower more. Didn't the old drag cars have the nose way up kind of gasser style. ;-)
 Post Posted: Fri Feb 10, 2012 6:24 am
I think your going to need a bump steer kit,I did after i installed trz upper&lower control arms on my 86 ss Monte Carlo
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Fri Feb 10, 2012 7:33 pm
I hope not. What was it doing?
Fresh pictures. 1 week of settle.
1 week ago
 Post Posted: Mon Feb 13, 2012 2:42 pm
Thanks Jeff. Are you kin to the Winters out of Mich? Greg, Doug, Jake.
 Post Posted: Tue Feb 14, 2012 6:38 am
No,whole family from PA.I was born and raised in MD.I thought I didnt need the bump steer but I did,I was trying to get the kit cheap.Only one way to find out and that is making passes.
Jeff
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Tue Feb 14, 2012 8:20 am
You can measure the toe change at ride weight and again as you jack the car up taking weight off of the suspension. This can be done using a couple of straight edges and a measuring tape. You have to measure behind and in front of the axle center and do the math for each point of measurement. It's a crude method but it will give you an idea if there is a lot of bump steer in it. I check the bump steer on the alignment rack any time I work on a car that has suspension or chassis mods. It really needs an alignment anyway because of the parts that were changed so that would be a good time to check it. The problem with the average tire store/alignment shop is they don't understand bump steer and rarely do a decent job on aligning a car. Steve, If you want to give me a call I can handle the job. I do all the alignments for Fast Chassis including the pro mods he builds.
 Post Posted: Tue Feb 14, 2012 9:07 am
Jeff, it was a stab in the dark. LOL the Winters run in NMCA NMC,Open Comp, EFI and I think Mean Street. I looked at the bump steer kit on the TRZ web site and it just looks like Tie Rod ends. Did you run stock spindles?
Chuck Jake was planning on taking it to work and doing it there but you brought up some great points. :-k Let me talk to Jake and see what he wants to do with the new info.
 Post Posted: Tue Feb 14, 2012 9:35 am
I didn't realize Jake had access to an alignment rack. If it's something he's going to do himself you can get him to give me a call and I'll explain to him how to check the bump steer. If it's a problem he will have to have a bump steer kit but there are a couple of ways to correct it.
 Post Posted: Tue Feb 14, 2012 9:39 am
Thanks Chuck. Right now there are no shims in it and it is all out of wack LOL. I got you on speed dial ;-)
 Post Posted: Tue Feb 14, 2012 2:21 pm
TRZ BUMP STEER COMES WITH NEW TIE RODS,I RUN STRANGE 4 PISTON DISK BRAKES IN THE FRONT ,I HAD TO DO SOME CUTTING AND DRILLING TO THE STOCK SPINDLE FOR THE BRAKES.I USE QA1 SINGLE ADJUST COILOVER SHOCKS.
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Tue Feb 14, 2012 7:07 pm
Yeah we had to cut off the old caliper mounts and drill and tap 2 of the back plate holes.
