DCarr
Posted: Sun May 02, 2010 6:25 pm |
This as been keeping me busy the last few months. 40' x 30' x 13', already wish I would've gone 48' x 36'  Plenty of parking and turn around space. Graded area is approx. 100' x 100'  From the back of our House
Beretta
Posted: Sun May 02, 2010 7:32 pm |
WOW...........That is nice...Only problem with that is I would move in
tonyy358
Posted: Mon May 03, 2010 5:44 pm |
Joined: Tue Apr 18, 2006 10:11 pm Posts: 2922 Location: NJ
sweet, how the hell you been?
_________________ ecbrc high point boat overall 2008
traysvega
Posted: Mon May 03, 2010 6:22 pm |
spib
Posted: Thu May 20, 2010 5:37 pm |
Joined: Wed Apr 19, 2006 4:31 pm Posts: 521 Location: EastWenatchee,WA
thats going to be very nice shop
WR169
Posted: Thu May 20, 2010 5:49 pm |
Joined: Wed Dec 06, 2006 9:24 pm Posts: 5071 Location: Elizabethtown, KY
_________________ Steve 6.7772 @ 101.51 1/8th 10.747 @ 122.24 1/4
DCarr
Posted: Mon May 31, 2010 7:46 pm |
Thanks for the comments !! Its been awhile coming. But once I pulled the permit ( 3/3/10), things have gone fairly well. We've now got 3/4 of the metal siding on it now, was to hot and humid to do more than we did. Maybe have power in it at the end of the week ?
DCarr
Posted: Mon May 31, 2010 7:48 pm |
WR169 wrote: Your right ... I started out planning on a 40 x 60 ... but after the grading was done, that size shed just wasnt going to fit on there easily. Its easy enough to add on to it, or bulled a small shed onto the side for all the stuff in storage.
Ken0069
Posted: Tue Jun 01, 2010 1:37 pm |
Site Admin |
Joined: Tue Apr 18, 2006 6:38 am Posts: 11656 Location: Coming At Ya!
Hummm, don't know how I missed this one? Looking good though Duane.
Just make sure you put plenty of insulation inside that thing. First summer in mine without it was unbearable most of the time then winter was worse that that at the opposite end of the scale and down in the 30s at times. Insulation will help keep the heat in in the winter and it will also help keep it out in the summer. Now if I could only afford air conditioning I'd be set.
DCarr
Posted: Tue Jun 01, 2010 3:06 pm |
Ken0069 wrote: Hummm, don't know how I missed this one? Looking good though Duane.
Just make sure you put plenty of insulation inside that thing. First summer in mine without it was unbearable most of the time then winter was worse that that at the opposite end of the scale and down in the 30s at times. Insulation will help keep the heat in in the winter and it will also help keep it out in the summer. Now if I could only afford air conditioning I'd be set. Ken, Right now the building is wrapped in a foil / fiberglass / plastic that is rated at R 11 ( as I was told ). Plan is to insulate the rest will take a year or so at least. But since the walls are 2" x 6" I am planning on going with a R19 at least ... maybe an R 32 ( correct rating ? ) and then probably then blow in for the ceiling. But no doubt it is going to be unbearable until I get it insulated, walls and ceiling up and a heating & cooling unit. Thing that sucks is that all utilities will be commercial rates since it will have its own meter and its not a dwelling.
