 Post subject: marks 385
 Post Posted: Sun Dec 27, 2009 11:32 pm
on my cowl hood I will probably paint 401k maybee 401k loan
anyways looks like she is done, will stay at machine shop untill around
march or april, still need a few lil parts, and pro system carb and
$750 for a day at the dyno
oh yes , need to get a glide and a brake and shifter also :shock:
385, my blazer should run, this will be all motor
lookin to go 10.90
should be 580-600 hp
http://www.s10dragracer.com/
 Post subject: Re: marks 385
 Post Posted: Mon Dec 28, 2009 6:03 am
Looks Good Mark!! \:D/ \:D/
 Post Posted: Mon Dec 28, 2009 7:24 am
Looking Good Mark. That should give you what you need to get that 10.90. \:D/ \:D/ \:D/ \:D/
 Post Posted: Tue Dec 29, 2009 12:56 pm
Looks Great =D>
http://www.sommersracing.net
 Post Posted: Tue Dec 29, 2009 5:31 pm
Looks good Mark but if that is a cast cam gear it won't last to long and I would change it now before
you drop it in...With a roller cam and good spring pressure along with small block RPM the cam gear will
start dropping teeth.....Not something you want going through your new motor ;-) ..
 Post Posted: Tue Dec 29, 2009 6:04 pm
I will check with motor builder but I am sure that is not a cast cam gear
 Post Posted: Tue Dec 29, 2009 8:04 pm
Here's what it will end up looking like..
 Post Posted: Fri Jan 01, 2010 10:02 am
Hey Mark , what head is that 220,227?
 Post Posted: Fri Jan 01, 2010 10:44 am
210
 Post Posted: Fri Jan 08, 2010 10:04 am
AFR makes some great heads you will be happy with them for sure,those shaft rockers looked like they were offset that is why I thought it was one of the bigger heads,I have the 227's and I love them!
Users browsing this forum: Yahoo [Bot] and 0 guests
