Tanner
Posted: Tue Jan 06, 2009 5:31 am |
Joined: Sat Apr 22, 2006 4:29 pm Posts: 471 Location: Longview, Tx
Beautiful rod!!!  Not to nit pick, but isn't the window net supposed to be mounted within the funny car cage bars?
-Tanner
hotrodharley
Posted: Tue Jan 06, 2009 8:56 am |
Joined: Tue Apr 18, 2006 10:36 pm Posts: 173 Location: spring creek nv
Tanner wrote: Beautiful rod!!!  Not to nit pick, but isn't the window net supposed to be mounted within the funny car cage bars? -Tanner
thanks tanner about bringing that up about net..if it is then now is time to change it before i paint cage..
ok;;everyone lets hear it about the net.how is it to be mounted?
Beretta
Posted: Tue Jan 06, 2009 9:24 am |
I think the X bar to the sholder is to low also
Bubstr
Posted: Tue Jan 06, 2009 10:01 am |
Joined: Tue Apr 18, 2006 9:54 pm Posts: 1619 Location: Western Illinois
The Tangerine color makes my zipper quiver. Now that is a color for a race car. I always liked wagons..
_________________ Older I get the less I know for sure Dennis
hotrodharley
Posted: Tue Jan 06, 2009 10:43 am |
Beretta wrote: I think the X bar to the sholder is to low also
it looks to low in pics but i'm a 1" from max that i'm allowed.if needed i can also slide down in seat and gain another 1" to make tech happy..another thing on X bars that no one has noticed or said anything about is where they cross at..in spec book i couldn't find anything about that because i wanted to off set them as you see in pic[for a differant look and to make a little esay to get in]called nhra tech guy and he said i could offset up to 6"[not in book but if he said he was good with it then thats good for me]
if anything else you guys see that doesn't look right PLEASE let me know so i can check on it.i've got to take car 260 miles[one way]to get it certified. only want to do once.
Avery
Posted: Tue Jan 06, 2009 6:55 pm |
Joined: Wed Apr 19, 2006 3:48 am Posts: 834 Location: Lenoir City Tennessee
gearhead1011
Posted: Tue Jan 06, 2009 9:32 pm |
Joined: Wed Apr 19, 2006 4:11 pm Posts: 2749 Location: Shepherdsville, KY
hotrodharley wrote: Beretta wrote: I think the X bar to the sholder is to low also  if anything else you guys see that doesn't look right PLEASE let me know so i can check on it.i've got to take car 260 miles[one way]to get it certified. only want to do once.
The bar does look a little low but if it falls within NHRA spec it should be ok. The window net looks like it's positioned correctly but I think the front lower mount needs to be attached to the door bar. That net is supposed to keep your hands and arms inside the protection of the chassis in case of a roll over. I was told that when a drag car (especially one with 'glass doors) rolls over the 1st thing to happen is the doors fly off. I wouldn't compromise safety for the sake of making it easier to get in and out of the car.
_________________ Chuck Woloch Chuck's Automotive Full line Computech dealer chucksautomotive@yahoo.com
hotrodharley
Posted: Tue Jan 06, 2009 10:22 pm |
chuck;;;can i just bolt a small cable to a tab on bar and then hook on bottom of net frame i built?on the door bar i set in seat and had girlfriend mark the main hoop bar at top of shoulder with sharper and hand hands on steering wheel as if i was driving and she marked on door bar where my elbow was at..i then stayed inbetween these marks.in the spec book the way i read it is bar got to be between shoulder and elbow but not lower then 4" or 6" below shoulder.don't remember exact measurement.i went as low as max below shoulder that spec book said i could go.
gearhead1011
Posted: Tue Jan 06, 2009 11:58 pm |
hotrodharley wrote: chuck;;;can i just bolt a small cable to a tab on bar and then hook on bottom of net frame i built?on the door bar i set in seat and had girlfriend mark the main hoop bar at top of shoulder with sharper and hand hands on steering wheel as if i was driving and she marked on door bar where my elbow was at..i then stayed inbetween these marks.in the spec book the way i read it is bar got to be between shoulder and elbow but not lower then 4" or 6" below shoulder.don't remember exact measurement.i went as low as max below shoulder that spec book said i could go.
I've seen a lot of nets tethered with a cable go through tech so that might be ok.
From the 2009 NHRA rulebook page 261-262.
Sidebar must be included on the driver's side and must pass the driver at a point midway between the shoulder and elbow.
It states that the crossbar (side to side of the main hoop) must be installed no lower than 4 inches below, and not above, the driver's shoulders. That's the only reference to a dimension from the shoulders I can find.
I would think with the funny car cage you should be safe but you might want to check with a tech guy before you finish up.
Beretta
Posted: Wed Jan 07, 2009 7:22 am |
That cable to the X-bar I don't think is good just get a custom made net and attach it to the lower bar.... I'll get a few pic's of mine tonight and post them. It will be easy to do and when down it's totally out of the way...IMO =;
hotrodharley
Posted: Wed Jan 07, 2009 8:54 am |
Beretta wrote: That cable to the X-bar I don't think is good just get a custom made net and attach it to the lower bar.... I'll get a few pic's of mine tonight and post them. It will be easy to do and when down it's totally out of the way...IMO =;
that would be great.i'm going out to garge todasy and recheck the side bars also.chuck gave me the specs on them so i can recheck bars.want everything right on car.
thanks
hotrodharley
Posted: Wed Jan 07, 2009 10:51 pm |
i check the back bar going across main hoop and it just made it in specs.i'm 4" below shoulders. the X bars[door bars]passes also .meets hoop half way between shoulder and elbow..i'm borderline but within what nhra wants.now if my tech inspector measures same way then i'm good..
now need to get window net took care of..anything else that you see in my pic you think i need to change or check?pleasse let me know..i want car safe and right.
Beretta
Posted: Thu Jan 08, 2009 9:07 pm |
You have an e-mail as It was easier for me to do that than post it here
hotrodharley
Posted: Thu Jan 08, 2009 10:20 pm |
thanks berry..very nice clean job..must redo mine for sure now
hotrodharley
Posted: Thu Nov 12, 2009 7:49 pm |
