 Post subject: MSD universal plug wires
 Post Posted: Wed Dec 10, 2008 2:57 pm
Hi, has anyone used universal spark plug wires. The ones that come straight and can be bend to 90 degrees. I have some header,plug wire issues. If so how did they work and do you like them. Thanks
 Post Posted: Wed Dec 10, 2008 5:13 pm
I would go with Belden  =; "NAPA"Get the good stuff \:D/  \:D/  \:D/
 Post Posted: Thu Dec 11, 2008 12:37 pm
Tony, Are looking at these??
http://www.msdignition.com/Products/Spa ... t/HEI.aspx
 Post subject: wire
 Post Posted: Thu Dec 11, 2008 5:14 pm
Yes, there the ones I was looking at, except for an 8 cylinder that wire set is for a 4 cylinder [-o< =;
 Post Posted: Thu Dec 11, 2008 5:45 pm
SO JUST GET 2 SETS [-o<  [-o<  =;
 Post Posted: Fri Dec 12, 2008 1:15 am
I have those and ran those there not that good well for me they wasn't anyway i have a header problem also just use the 90's on both ends that long boot want stay were you bend it or at least mine didn't it still got against the header and caught on fire as far as  running they did fine but i never could get them to stay were i put them. Good luck
 Post Posted: Mon Dec 15, 2008 7:12 pm
Gotem on the stang..worked great..bend the spark plug end just the way I wanted it...I've got little headers though...  =;
Also dont know how well they do at a 90 degree....Mine are at  a 45 on most...
 Post subject: reply
 Post Posted: Tue Dec 16, 2008 9:38 am
These worked great on my gib block in my chassis with custom headers, I just bent them to where I needed them and Waaalaaaaa on and tight =D>  =D>  =D>  and as long as you support and seperate the wires going down to the plugs, you should not have any problems.  My 2 cents.
