Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post Posted: Sun May 18, 2008 5:30 pm
here are pic's of the hull we just purchased, needs some work and a paint job. will post pic's of progress. we raced against this boat in 2004 our first year out.
 Post Posted: Sun May 18, 2008 9:45 pm
here is a pic of race garvey from about 1992, the boy wants to paint it the same color and possilbly use the same name, ( lickity split ).
 Post Posted: Mon May 19, 2008 5:32 am
I always watch your boat related posts. I used to be involved in boat racing. We ran outboard powered hydros and runabouts. C modified hydro (APBA) was the class we ran best in. Good luck with the new hull.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Mon May 19, 2008 11:01 am
I see you have a lot of sanding and painting to do. Is all the holes in the transom for a jack plate? How does this hull match up with the one your running now?  I figure over all weight makes a difference, but does front to back side to side or even center of gravity hight make a difference?
Nothing like a new build to get you excited no matter what kind of racing.
 Post Posted: Mon May 19, 2008 8:29 pm
thank's old timer.. \:D/
bubster, the hull is diffrent from the extreme, the new hull is a chine boat, the chines are at 30 deg. it is lighter by 350 lbs which is not a good thing and also shorter by 1ft 8 in which is a disadvantage also. the water we been running has been hard on these smaller boats but it was available and affordable, we use to smoke this boat with the extreme but it was under powered. my 283 will bring this boat to life just hope it stays on the water =;  =; i have not checked the hull desighn yet on the bottom to see how it will ride on the water, will check it soon and figure how i want the plate adjusted..
thank's tony.
will keep you updated...
 Post Posted: Tue May 20, 2008 6:19 am
New projects are fun. It just doesn't look like much as a bare hull. But I'm sure it will be awesome when completed. =;
 Post subject: UPDATE.
 Post Posted: Mon May 26, 2008 7:14 pm
THE HULL IS SANDED, STERN GUNNEL IS REMOVED AND READY FOR REPAIR. LAST PIC SHOWS A STRINGER REPAIR THAT WAS CRACKED.
 Post Posted: Mon May 26, 2008 7:36 pm
Nice Chevelle frame you have there Tony, how is it coming along? =;
The new hull looks like it is coming along nicely, when do you expect to have it out by?
 Post Posted: Mon May 26, 2008 7:38 pm
before the chevelle. ;-)  =;  =; trying to make first race on the 8th.
 Post Posted: Mon May 26, 2008 8:44 pm
Congrats Tony!! Nice  having the kids do all the hard stuff LOL  I know  "your training them"   ;-)   :-$  =;  =;  =;  =;  =;  =;  =;
 Post Posted: Mon May 26, 2008 8:50 pm
I noticed in the 1st pics the guys are wearing coats. Then in the last ones all short sleeves and 1 guy without a shirt.  Now tony 1st posted this about a week ago so it looks like the weather changes there like it does in Kentucky =;  =;
 Post Posted: Mon May 26, 2008 9:03 pm
yep, weather change is drastic, yesterday in coats and today in shorts and tonight back in coats. #-o   just had to put the jet heater on last coat of fiberglass to get it to kick off and harden it is about to rain again glad i went out and checked. #-o
 Post Posted: Sun Jun 01, 2008 8:47 pm
So is this new boat replacing last year's Championship winning boat, or is it an addition to the team? Either way, good luck with it, being an X-Drag boat racer myself, I always enjoy reading your posts to see how you guys are doing. \:D/  \:D/  \:D/
 Post Posted: Sun Jun 01, 2008 9:32 pm
it is an addition to the team, my son mike turned 18 and will drive the boat in stock 315 2bbl class, using the 283 2bbl from the extreme. so we will run stock 2bbl and 4bbl classes.. the boat has potencial and i am working on the setup to make it a front runner, have watched the boat race since it was built in 1992 and have raced against it, we smoked this boat with the extreme in virginia in 04, i noticed many problems watching it and hopefully will be able to correct them.
 Post Posted: Fri Jul 04, 2008 7:12 pm
primed the second hull today, making some headway...
http://images.streetfire.net/photos/000 ... 158214.jpg
http://images.streetfire.net/photos/000 ... 158215.jpg
Users browsing this forum: Yahoo [Bot] and 1 guest
