Post new topic Reply to topic  [ 147 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 10  Next
 Post Posted: Sun Dec 16, 2007 6:37 pm
[URL=http://goodtimes.webshots.com/photo/2424333550096533149QLMhfz]Image
I have transferred the chassis to the rotisserie to weld it up. The legs on the jig have been folded up to make more room. A soon as I finish welding the chassis, I will set it back on the jig and fit the cage. The seat braces have been added and the carbon fiber seat trimmed to fit.
I had to go back to a forward mounted tank. There is not enough room between the engine and the cage for the rear fuel tank. The Afco radiator is mounted to the rear deflector with rubber bushings.
]Image[/URL]
Had I known the engine compartment would be this tight I would have gone to a 235-245" wheelbase with another 5" added to the engine compartment. Live and learn.
John   :-  :-$
Hat Injection Is Nice, But I Had Rather Be Blown!
 Post Posted: Sun Dec 16, 2007 8:01 pm
That's looking good John and it looks like your really moving along nicely..  \:D/  \:D/
 Post Posted: Sat Dec 22, 2007 6:30 pm
Plenty of room there John  ;-)
 Post Posted: Sat Jan 12, 2008 7:59 pm
John,
       Comming along nicely. Can't wait to see it all decked out.
I was wondering when you finish the welding the frame did the upright pull the bottom rails? My altered I just put on a frame jig shows that almost every upright pulled the bottom rail about a 1/8" in a 1' span. I put it on the jig because I tweaked the front A arms on a wheel stand and decided to build a jig. The guy who I purchased the chrome moly chassis from is no longer around. Just wondering if yours pulled up a littel at every upright.
Thanks,
Doug
 Post Posted: Sat Jan 26, 2008 2:52 pm
altereddoug wrote:
John,
Thanks,
Doug
Doug:
        My bottom rails did not pull.  The jig held the rails nicely.
 Post Posted: Sat Jan 26, 2008 3:05 pm
It has been awhile since I posted any news on this project. I started a new job and it has been taking most of my time this month. The cage is done except for the helmet bars. I had to leave them out so I could get my head between the bars to do the welding. The cherry picker made it easy to turn it upside down to weld the cage. It was too close to the floor on the rotisserie to weld.
I feel like I am in a steel cocoon when I set in it. Tight fit at 23" wide for my 6', 275 lb. frame.
 Post Posted: Sat Jan 26, 2008 9:07 pm
Looking good John, Their is something about a unpainted rolling chassis that is prettier than a finished car.  Maybe because it's naked.  I do like naked.  I look forward to your updates. You got to be proud of what you have done so far.
 Post Posted: Sun Jan 27, 2008 5:29 pm
I've been waiting to see / hear about your progress. Looks really good and as Bubster said, you should be proud of what you've done.
Will you be using alum. body panels for it or a 1 pc. fiberglass body ?
 Post Posted: Sun Jan 27, 2008 5:54 pm
I have an aluminum body KIT. You have to do alot of flanging, bending, and cutting to get it to fit. It will take me awhile to get it fitted correctly.
The aluminum body is uncharted territory for me. I have a bead roller with flange dies that I will be using with this portion of the build.
John =;
 Post Posted: Sun Jan 27, 2008 6:56 pm
I'm not a dragster guy at all, but being a fabrication junkie, I really enjoyed reading and watching your progress.
Looks like it's coming along quite well. Should be a real sense of accomplishement when your done.
 Post Posted: Wed Feb 20, 2008 5:58 pm
John looks like you are making good progress on the dragster .
it's looking good from here keep up the good work and enjoy that's something to be proud of building your own car.
Cant wait to see the finished product. \:D/
 Post Posted: Wed Feb 20, 2008 7:19 pm
Were about due for a progress report. It has been an interesting build to follow.
 Post Posted: Wed Feb 20, 2008 7:48 pm
Yes it's time for a fabricating fix. My name is Bubstr and I have a fabricating problem.
 Post Posted: Wed Feb 20, 2008 9:16 pm
Car is looking great.  Definately looking forward to the finished product.  Keep up the good work!!!
Mark Goulette
 Post Posted: Sat Mar 01, 2008 4:17 pm
Guys:
        The aluminum body is going real slow. I only have Saturdays to work on the dragster. I need some experienced guys to help with the bending and flanging the body panels. So far, no help has been available. You only get one shot with these panels and they cost too much to screw up.
Users browsing this forum: Bing [Bot] and 0 guests
