 Post Posted: Wed Apr 26, 2006 7:25 pm
radicalz wrote:
rodrocket wrote:
thanks for that Tony
car sits a couple of inches lower now but apart from that there is little that has changed
were did i go wrong trying to post the pic's
regards
rod
I hope this helps....Rod if you right click on the pictures Tony put up for you....go down to properties....like Zach said and you will see these addresses....from the bottom up....
http://i5.photobucket.com/albums/y172/r ... 010642.jpg
http://i5.photobucket.com/albums/y172/r ... rneath.jpg
http://i5.photobucket.com/albums/y172/r ... inRear.jpg
....ok to get the image to appear on here or in your signature or avatar...you must put.....img....in these brackets....[ ]....at the beginning of the address....and..../img....in these brackets.....[ ]....at the end of the address.....each address begins with http and ends with the jpg....hope it helps.... :-k :-k
Yea Thats as clear as MUD!!!!!!!!! [-( [-( [-(
 Post Posted: Thu Apr 27, 2006 4:42 am
ProStreet83C10 wrote:
why do u have 2 shift lights on your tach
yellow is the shift light
the red one is to let you know that the oil pressure is low
regards
rod
 Post Posted: Thu Apr 27, 2006 9:59 am
how the hell did you rig up a red shift light for an oil warning light....
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Thu Apr 27, 2006 7:15 pm
it runs a "tee" peice off the back of the block from there the standard tube connects to one outlet & a Autometer electric oil pressure switch to the other
the oil pressure switch will glow the light at anything under 30Psi
regards
rod
 Post Posted: Thu Apr 27, 2006 7:32 pm
nice ride rod ill keep an eye out at heathcote next time im there
 Post Posted: Thu Apr 27, 2006 9:39 pm
regards
rod
boy id REALLY be in trouble i fi had that....i run 7-12 lbs of oil at idle warm in gear
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Fri Apr 28, 2006 5:39 am
isnt that a little on the low side
what Rpm do you turn that thing to & whats the oil pressure like up there
regards
rod
 Post Posted: Fri Apr 28, 2006 5:46 am
forgot to add that i just checked on the pressure switch & found that its actually a 18 Psi switch
Autometer make 3 different switches
18 Psi part number 3241
30 Psi part number 3242
50 Psi part number 3243
i must have been out of the car for to long, carnt wait to get this thing back out there
regards
rod
 Post Posted: Fri Apr 28, 2006 6:27 pm
regards
rod
....sorry Barry....when you click on the pic that Tony posted or anybody has up....right click the mouse on the picture and a menu will come up.....scroll down to properties...usually at the bottom of the menu....click on properties.....then you will see on the screen that pops up a URL address.....this is where the pic is.....now to get the pic in either you signature or the avatar...you must put.....img....in these brackets....[ ]....at the beginning of the address....and..../img....in these brackets.....[ ]....at the end........or tell where the pic is by posting the address and we will help ya post it....Tray is the signature master....he will need other information.....so PM him :-k :-k :-k .....just trying to help.....
James
79 Z28 496 BBC....
 Post Posted: Fri May 05, 2006 9:04 pm
Wow where the heck was I?Sorry I missed this...Prob out ridin that dang motorscooter of mine :-k
