 Post Posted: Sat Jul 31, 2010 5:13 am
Hi all, a couple of pics of my slow build. Its torana coupe with 598 talldeck and glide. Engine made around 980 asp here in Australia (sold as 1030 in the us ) and we have set up to take a fourhundred shot as well . car weighs arpond 3100lb . Image
 Post Posted: Sat Jul 31, 2010 5:15 am
 Post Posted: Sat Jul 31, 2010 5:18 am
 Post Posted: Sat Jul 31, 2010 5:22 am
our other one with a small block . ImageImage
 Post Posted: Sat Jul 31, 2010 7:03 am
That should open your eyes when you hit the gas O:) O:) ...That looks like a Vega sort of I guess #-o ...What is in it for a rear/cage/trans/ Tell us more or did I miss that????
Nice job though \:D/ \:D/ \:D/
 Post Posted: Sat Jul 31, 2010 1:09 pm
Looks like you pay alot of attention to detail. Really nice car. Very Clean looking. good Job let us know what it runs.. Any idea when you will get it to the track with the new Bullet?
 Post Posted: Sat Jul 31, 2010 5:48 pm
The trans is a deadenbear case glide with 1.8 gear set , roller tail etc. the converter is a mechanical diode made here in australia and should give me around 5500 rpm. the rear end at this stage is a modified factory rear which is a bit like a four link. there are some of these casrs running 7.70 on 11.5 and the same rear end here . I am going to try radials i think however i have some slicks as well. i am at the moment trying to get some weight out of the car with glass bits and alluminium brackets etc. the cage is a ten point moly cage ,Imagethe pipes and ignition are the ones we used on the dyno . i am using a digi 7 , and edelb rock controller for the gas .ImageImage
 Post Posted: Sat Jul 31, 2010 5:53 pm
Image the fabricator sayin nooooooo
