 Post subject: MUSTANG HATCH
 Post Posted: Sat Feb 09, 2008 8:59 am
Just thought i would post some pics of my turd going together.
It' an 84 hatch with newer  front sheet metal -the paint is off a 2008 saturn
i did all the body work and had a buddy shoot it for me,i built the rearend, am building the engine,and fit and tacked in the cage myself ,and then had a pro do final tig welding on the cage
the car is setup for a sb chevy [-(
8.8 rear with strange axles and spool,double adj uppers and lowers with a upr antiroll bar,lakewood shocks
all upr front suspension with coilovers, an aje k-member
12 point cage(major bars are mild 1-5/8", but all smaller bars are moly, with frame connectors running through the floor and  some bars tied into the strut towers
hoping to run soem local heads up stuff with it
car actually started life as a hertz rent a car lol ;-)
well i'll post some more pics as i get farther along
crossbreed
 Post Posted: Sat Feb 09, 2008 9:07 am
looks good!!!!Nice Job \:D/  \:D/
What's your plans for the engine :-k  =;  =;
 Post Posted: Sat Feb 09, 2008 10:52 am
\:D/  \:D/  \:D/  \:D/  \:D/  \:D/
 Post Posted: Sat Feb 09, 2008 12:16 pm
I like the color on there .
Nice \:D/  \:D/
 Post Posted: Sat Feb 09, 2008 12:33 pm
Very cool, that little car should fly!!! \:D/  \:D/  \:D/
 Post Posted: Sat Feb 09, 2008 2:16 pm
Looks good Nick, are you going to be ready by may 1st?
\:D/
 Post Posted: Sat Feb 09, 2008 10:35 pm
Looking good  \:D/  \:D/  \:D/  \:D/  \:D/
 Post Posted: Sun Feb 10, 2008 1:22 pm
thanks for the nice reply and kind words.the engne going in the car is a small block chevy .a similar engine (same cubes)but with alot less cyl head,unported intake,less carb,gear,no vacuum pump,reg tension rings,etc(you get the point ,it's alot milder),in a car that weighs 500 pds more,on a small 150-160 shot ,runs 10teens here in denver.
my chassis was duplicated from a friends car that only runs low 10s ,but sixty foots in the mid 1.30 range.
these little furds work pretty good lol
so im hoping for mid to low nines when its sorted out
i'll post some more pics soon
Crossbreed.
 Post Posted: Sun Feb 10, 2008 4:13 pm
VERY SWEET LOOKING =D>  =D>  =D> ---GOOD LUCK \:D/  \:D/ ---LIVELY
"GASSERS ARE A GAS"
