 Post subject: Headers
 Post Posted: Mon Jan 08, 2007 12:12 pm
Well the headers are done!!! I'll try to get some pics posted tonight... We left some room so hopefully they will fit my other heads as there raised exhaust ports...
Does anyone know if the angle where the flange of the header sits are all the same??????
Maybe fire it up this weekend =; =; =;Image
 Post subject: Re: Headers
 Post Posted: Mon Jan 08, 2007 2:24 pm
Maybe some vid of a burnout??!!
 Post Posted: Mon Jan 08, 2007 5:06 pm
barry you shouldnt have any problems with the flanges my old headers fit my big cheif heads and they was raised and on a tall deck you should be fine
 Post Posted: Mon Jan 08, 2007 7:25 pm
Here's another pic......... =; Image
 Post Posted: Mon Jan 08, 2007 8:00 pm
look real nice barry. \:D/ what are you going to coat them with?
 Post Posted: Mon Jan 08, 2007 8:06 pm
barry looks like a super job nice tig work ya those will fit your heads looks like you got pleanty of room. =; \:D/
 Post Posted: Mon Jan 08, 2007 9:06 pm
Tony, I really want to make sure they fit my other heads,,,Im pretty sure they will there's lots of room but if they don't I'll make another set...
If they fit then I'll put the other 7 egt fittings and the 02 sensors bungs in them and have them jet hot coated....... =;
 Post Posted: Tue Jan 09, 2007 7:32 am
Looking very good Barry. \:D/ \:D/
 Post Posted: Tue Jan 09, 2007 6:03 pm
Was that a weld up kit barry ?
Sam
 Post Posted: Tue Jan 09, 2007 6:07 pm
Sort of... Just headman kit plus some extra bends and slip on
Hooker collectors =; =;
 Post Posted: Tue Jan 09, 2007 6:09 pm
what size pipe did you go for ??
I've got a big stash of stainless bends from 1.75 to 2.25 diameter of of some roundy round engine probably enough to build a new set and very light... =; =;
Sam
 Post Posted: Tue Jan 09, 2007 6:13 pm
I used 2 1/8 as thats what the vega had..
 Post Posted: Tue Jan 09, 2007 6:14 pm
I'd better make a set ,,, rick said smaller would be better
Sam
 Post Posted: Tue Jan 09, 2007 6:19 pm
I asked a few guys on other posts and this is what size they would use and about 28 ti 30 inch tube..would be good up to a 496....The vega worked will with that size so it must have been ok..
Georges new car has the same size but his camaro had 2 1/4 so that would have been a good test between the two :-k
 Post Posted: Tue Jan 09, 2007 6:21 pm
I've got 2 and 1/4 and a set of 21/4 stepped to 2 3/8 in stock.. need the 2.1/8 to make the set really
Sam
