 Post subject: Rear gear ?
 Post Posted: Sat Oct 20, 2012 10:35 am
When running the 1/4 mile my rpm at the stripe is 7620 with the 4.29 gear...Question is If I go with a 4.11 rear gear
do you think it will help any as the rpm will be somewhere about 7300.. #-o
 Post subject: Re: Rear gear ?
 Post Posted: Sat Oct 20, 2012 12:45 pm
At what RPM do you make the gear change?
 Post Posted: Sat Oct 20, 2012 12:47 pm
It won't lower your ET if that's what you're after. your peak hp was at 7500 and it may have liked higher than that since that was as high as dyno'd.
 Post Posted: Sat Oct 20, 2012 3:46 pm
7000 usually, but have been experimenting some but seems not to make any difference..
 Post Posted: Sat Oct 20, 2012 3:49 pm
Well that 8.08 that's in my sig was with a 4.57 gear but it was way over 8000rpm... O:)
