 Post subject: Tilton Master Cylinder
 Post Posted: Sat Jun 09, 2012 3:20 pm
My dragster has a Tilton master cylinder on it with a poly reservoir that is held in place with one of those split wire clamps. That thing has leaked since day one and I've tightened the clamp several times but it still seeps enough fluid that it collects on the lower frame rail and drips in the floor.
So has anyone else had this problem and if so, did you find a solution for it??
 Post Posted: Sat Jun 09, 2012 4:58 pm
Never seen one of those..Only kind I have seen have a AN fitting screwed into the top with a remote reservoir. :-k
 Post Posted: Sat Jun 09, 2012 7:43 pm
This one is the 74 series and can be setup either way but I really don't want to mount the reservoir on the aluminum firewall in the foot box. It's a little too flimsy for that. :-k
 Post Posted: Mon Jun 11, 2012 7:27 am
I have that same master cylinder but have no leakage issues.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
