 Post subject: IRS Drag Race setup
 Post Posted: Fri Feb 24, 2012 8:17 am
Guys...I know 100% of NOTHING about suspension setup. I've seen IRS do 1.2 60ft times....how. I'm @ 1.72 right now. I run 345/30/18 BFG DR's. Watch the vid and let me know what needs to be tweeked. I have Moton shocks so they are fully adjustable. I do get a little spin off the line still. I was running tires pressure @ 18psi, this was also my 1st time ever out on DR's. Next time I'll drop to 16psi and hope it hooks a little better. What I do notice, is that the car doesn't squat. I get no lift on the front end. I did remove the front sway bar but I don't think it helped much.
http://www.youtube.com/watch?v=7j1xZ_JmMck
 Post subject: Re: IRS Drag Race setup
 Post Posted: Wed Feb 29, 2012 4:01 pm
Nobody have an idea on IRS setup for drag racing????
 Post Posted: Wed Feb 29, 2012 5:31 pm
Theres nothing much that you can setup. All you can do is find the best shocker setting. IRS doesnt react the wheels downwards into the ground at the instant of torque application. Normal 4 link or ladder bars shove the wheels down in response to the inertia of the wheel. IRS doesnt do that. IRS has a fixed IC at the front axle. Theres not much you can do with it without making it into something else.
 Post Posted: Thu Mar 01, 2012 7:06 am
I am not so sure I agree. Guys are getting 1.2 60ft times with IRS. SOMETHING has to be working.
 Post Posted: Thu Mar 01, 2012 8:32 am
What's there ET/MPH??????
 Post Posted: Thu Mar 01, 2012 2:29 pm
You asked about the design not the performance. 60' times comes from power and traction. If your not spinning the wheels excessively you have enough traction for your power. Just increase power and maybe get stickier tires and it will go faster 60'
 Post Posted: Thu Mar 01, 2012 5:24 pm
7.11@201mph....on M/T 315/60/15 DR's, full weight street car, nothing removed. He's looking for 6's. Below is a video of it doin' work.
http://www.youtube.com/watch?v=ZYpx-0HJMQ4
I love how it launches...just a little squat and it's gone. No Drama, nothin' just hooked and gone.
 Post Posted: Thu Mar 01, 2012 5:32 pm
Well a 1.2 time for 60' is slow for a car that can do 7.11 and 200mph. Which is what I would expect for an IRS rear end. IRS is not the way to go for traction snap.
 Post Posted: Thu Mar 01, 2012 6:13 pm
With what your car runs now, 1.12 short times still won't get you 7.11 on the other end. The guy in the video has got to have a bunch of stuff in the engine dept that you don't.
