 Post subject: Powerglide Build Specs
 Post Posted: Fri Jun 18, 2010 9:31 pm
Does anyone have specs on the proper clearances for a bracket powerglide?
Mainly wanting the rear clutches, the front clutch pack, and the end play...
Thanks
 Post Posted: Fri Jun 18, 2010 9:46 pm
http://www.amazon.com/Powerglide-Trans- ... 1557883556
Worth every penny and then some.
 Post Posted: Sun Jun 27, 2010 9:20 pm
I use 5 reverse frictions and set the clearence at .080 - .085 and 7 high gear frictions set at .100 no problems so far, toss the wavy steels in the trash and use all regular steels. The pistons can be milled on a brake lath also. ;-)
 Post Posted: Mon Jul 05, 2010 12:14 am
http://www.amazon.com/Powerglide-Trans-HP1355-Chevrolets-Applications/dp/1557883556
Yep, X2
