Slowpoke
Posted: Sat May 29, 2010 9:40 pm |
Joined: Wed Oct 24, 2007 6:36 pm Posts: 718 Location: Blanco, Texas
I have this converter and I am wondering if it will work with my new combo. Does anyone know what these numbers mean?
Thanks for any info,
_________________ Donee
Beretta
Posted: Sun May 30, 2010 5:57 am |
What Numbers
Ken0069
Posted: Sun May 30, 2010 8:32 am |
Site Admin |
OOPS, looks like another old fart brain fart, hey!
Slowpoke
Posted: Sun May 30, 2010 9:10 am |
Dang, I can't believe I did that and I reread it twice to make sure there were no mistakes!!!
Ok, here are the numbers on the Hughes: Gm-93 STD / 162770....(black marker) BS9B1........................... (stamped)
I also have this TCI: R02318-SR RO3162 1SR RO7197-5F 7409C 50PS 100P
I have been running the TCI in my Camaro 2800# w/driver, 496 9.50 @ 140, 1.35 60' 4.56 gear 1.76 low PG, 14/32 tire, stall @ leave 5600,shift 7200 fall back 5900.
New Combo: 555 BBC (As a 565 it made 957 hp @ 7200 and 775 tq @ 5600) I replaced the block and pistons everything else is virtually the same.
Thanks for the help
Slowpoke
Posted: Fri Jun 11, 2010 5:08 pm |
More info:
The guy I got the Hughes from said it stalled at around 5800 behind a BBC in a 3400# Nova that ran 10.30's with a 4.10 gear and 10 X 28 tire.
I called Hughes, the guy I talked to said it would be to tight for my combo and was "15 year old technology". The converter he would spec, would be a GM-95 that would stall at 6100 rpm.
For the price of $1095.00, I can step up to the right converter! I guess Ken's deal wasn't too shabby!
Looks like my Camaro won't be reaching it's maximum potential for a while!
Any suggestions on which one to run? I'm leaning toward the Hughes.
Thanks
Ken0069
Posted: Fri Jun 11, 2010 8:53 pm |
Site Admin |
Slowpoke wrote: More info:
Thanks Remember, Roniboi has a deal with BTE. So is there a problem with their converters? I've got 4 of'em and running 2 of'em with no complaints? Scott also runs'em and I don't hear him bitching? Talk to Brian Robinson at BTE. Find out what BTE part number Roniboi needs to order and then get him to give you a price before you spend any money. Talk is cheap!
Slowpoke
Posted: Sun Jun 13, 2010 7:33 am |
I think I'm going to run the hughes and a least get some info, should help if I have to get a new convertor to have some performance numbers.
Thanks
Ken0069
Posted: Sun Jun 13, 2010 8:14 am |
Site Admin |
I'd still talk to Brian at BTE. You could probably have them rework the one you have cheaper than buying new. The last 3 I sent them cost was in the $300/$400 range.
Slowpoke
Posted: Sun Jun 13, 2010 6:50 pm |
I will check with them before I spend any money, Thanks!
