 Post subject: PG Input shaft
 Post Posted: Sun May 02, 2010 9:03 am
I should already know this but my powerglide knowledge is nearly nonexistant. How do I tell the difference between a PG input shaft and a Turbo input shaft? The trans I have was in the car when I bought it and I really dont know much about it. I am going to be looking at getting a new convertor.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post subject: Re: PG Input shaft
 Post Posted: Sun May 02, 2010 9:12 am
Turbo Splines
PG Splines
Difference is in the converter end of the shaft.
 Post Posted: Sun May 02, 2010 11:56 am
Also with a Turbo converter, the input shaft support is in the front of the pump. There will be a bushing just inside the stator support for that input shaft. On a PG converter that support is built into the converter and there likely won't be a support bearing inside the stator support.
I just measured a Glide input and it's .875 diameter and has 17 splines. Don't have a turbo out but they will have more splines and probably be around 1 inch in diameter.
 Post Posted: Sun May 02, 2010 12:25 pm
The bushing depends on the converter, most of the newer stuff has a bushing in the converter and not needed in the stator support. And also not always good to use in that case as the bushing impedes flow through the converter.
 Post Posted: Sun May 02, 2010 2:20 pm
I guess I'm old school then as I wasn't aware that those support bushings were in the Turbo converters now.
The TCI/BTE input shafts I run have grooves cut in'em to allow fluid to flow around the shaft and since I'm not making that much power they seem to hold up OK. That's all I've ever run and I've never broken one. The input shaft that is in the Camaro now is one that gdmii was going to throw away after he broke that 1:76 planetary in his tranny. So far it's got two or three years of use on it and it's still in one piece. We replaced his old one with a ringless input/pump setup when we put the 1:80 straight cut planetary in it.
 Post Posted: Sun May 02, 2010 7:31 pm
Ken if you have that bushing in the stator tube I would take it out but may check with BTE first to make sure the support in the converter....
 Post Posted: Sun May 02, 2010 10:50 pm
Barry the converter that's in the car now is an old one I've had for years so I can pretty much guarantee that it doesn't have it. The Transmission Specialties one I'm going to put in may though. I'll check with BTE before I install it to see if they can tell me what it has.
 Post Posted: Mon May 03, 2010 4:40 am
Ken the support bushing is something they can add I think as when my old TCI unit us updated they put it in and I didn't ask for it....
 Post Posted: Mon May 03, 2010 10:55 am
That converter that is in the Camaro now was freshened up at BTE about 2 years ago? Maybe I'll give'm a call then to see if they might have updated mine.
