 Post Posted: Sun Mar 21, 2010 11:15 am
Racers,
What Powerglide Bellhousing is giving good service? What gives a good fit with no associated problems?
Larry Woodfin
www.woodfinautomotive.com
 Post Posted: Sun Mar 21, 2010 3:41 pm
I've got a JW Ultra Bell on mine that's been on that transmission in the Camaro for 4 years and I haven't had any problems with it. I've also got one of their roller bearing tail shaft housings too and that seems to be a good piece also.
 Post Posted: Sun Mar 21, 2010 4:30 pm
I also have the JW Ultrabell and their roller bearing tailshaft housing. Zero problems.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Sun Mar 21, 2010 5:30 pm
I also have the JW Ultra Bell on my Camaro and my spare trans, and when I upgrade the trans for my new engine I plan on stepping up to the roller bearing tail shaft housing too.
 Post Posted: Tue Apr 06, 2010 6:31 am
I run the Reid/Dedenbear trans case and roller tail housing also and I have ZERO problems with it, and my case also has an adjustable trans brake knob to adj if needed, and I would think the JW trans case also has one of these, does it guys???
I would run either case as they are both good case's and the ATI case is a good one also but I am now totally aware of any problems with there case and related parts.
I know all my glide parts from my stock case went right into a aftermarket case with no problems, my trans guy just would NOT use an aftermarket servo valve on the side as he says he has no idea's what the tolerences are and the stock GM ones are the best around, his words not mine and I run my trans hard and in a heavy chassis with a 1.80 straight cut gearset. My 2 cents.
