 Post subject: AUTO TRANS PROBLEM
 Post Posted: Wed Jan 27, 2010 3:55 am
Hi guys
When I select 1st, I can feel it engage but then it wont move an inch. I stall it up on the convertor and still no movement. Put it in Reverse and exactly the same thing. When I select Drive it moves forward and drives off but not as easily as it should, when it changes into second it then frees up and goes like normal.
Any ideas?
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
 Post subject: Re: AUTO TRANS PROBLEM
 Post Posted: Wed Jan 27, 2010 7:13 am
Have you ever run this tranny before or is it a new build?
What valve body is in it?
 Post Posted: Thu Jan 28, 2010 9:26 pm
Sounds like a valvebody problem to me too.
 Post Posted: Fri Jan 29, 2010 1:34 pm
Sounds like a valve body leak, maybe a gasket, or could be a blown up gear set. My car did the same thing when the planetaries exploded.
 Post Posted: Sat Jan 30, 2010 8:02 pm
Its a standard valve body, trans was working fine, sent it in for a freshen up. It got bearings, seals and clutches, a valve body and case surface and then an assemble. Was fine before the rebuild lol.
So you guys think valve body, could they have stuck a valve in the wrong way around or in the wrong hole, allowing fluid to go to both first and reverse. It feels like its engaging both those gears at once as the tranny gets real hot real quick. Im not using it as I dont want to damage the new stuff inside.
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
 Post Posted: Mon Feb 01, 2010 11:25 am
is it the glide in your signature ? I take it band adjustment is all good and not slipping ?. If you got a trans brake, are you sure it's not engaged ? wired wrong, switch burnt out ?
 Post Posted: Tue Feb 02, 2010 6:29 pm
Thanks Guys
Was a seal on the mainshaft that was the problem. On installation they nicked it and it allowed fluid to pass when one circuit was engaged.
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
