 Post subject: Brake Plumbing
 Post Posted: Sat Oct 31, 2009 6:15 am
Hey Guys,
The chassis is finally done, and now we're beginning to plumb the thing. My only question for now is; should the larger reservoir in the master cylinder be piped to the front, or does it matter? I'm using an 1 1/16 bore MC from an early 70's
Jeep. Rears are Willwood Dynalite's and front are GM calipers
Mike
Oh, I already am grey
 Post subject: Re: Brake Plumbing
 Post Posted: Sat Oct 31, 2009 6:49 am
You may need a different MC. If it has a small res. in the rear I would say it is for drum brakes. :-k Most of the guya I know use a MC from a Doge caravan ;-)
 Post Posted: Sat Oct 31, 2009 9:54 am
What year of Dodge Caravan?I know most of them have disc front drum rear,make a diff or not using it on a race car?
 Post Posted: Sat Oct 31, 2009 12:03 pm
I heard to use a Chrysler lebaron MC
 Post Posted: Sat Oct 31, 2009 1:44 pm
Ours is a for a 70 corvette manual disk brakes at Advanced Auto.
http://shop.advanceautoparts.com/webapp ... 5213898___
 Post Posted: Sat Oct 31, 2009 2:41 pm
Here you go Tray and a friend of a friend :-s uses one of these on his dart at 3800lbs and runs 8.90s at 150+....... O:)
http://www.dragstuff.com/techarticles/R ... CylPN.html
 Post Posted: Sat Oct 31, 2009 7:26 pm
Very nice ,Thanks Barry!
 Post Posted: Tue Nov 10, 2009 8:58 am
Ok, traded in the MC I had and got the one from the Dodge PU that Barry suggested. The part numbers in the article didn't seem to be good. The one I ended up with is cast, not aluminum, no big deal, it's still lighter than the last one I had. I was just checking back to look for the PN of the fittings, but I know the they are not 9/16 like the description says. Actually the plastic fittings that came with it for bench bleeding don't even fit.
Guess when I pull it back off, its back to the parts store to try to find the fittings. I'm using 3/16 steel brake line from the MC to line lock and proportioning valve. To me they look more like 1/4 or 3/8 and they are both the same. The MC supposedly has an 1 1/8 bore...
