 Post subject: new car NO#
 Post Posted: Fri Oct 30, 2009 2:44 pm
Well we got the car on the scales After i got back from the doctor this crap is killing me so here is what we got.
The four link was set way out it was 67 1/4 and 10 1/2 So no wander it was getting loose
And with the unequal four link i am very limited on the settings.
So the two that i had to choose from was 57 and 6 3/4 up or 49 and 8 up so i went with the 57 and 6 3/4 up the wheel base is 120" so that is a little less than half i will try it there first and see what happens the old shocks was not adjustable so i put a set of Qa1's and a 110 spring on it the old springs was 130.
The scale NO#'s LF 693 RF 653 LR 606 RR 678 Weight Percentage Front 51.2 Rear 48.8 2631 LBS
With me in the car LF 774 RF 644 LR 672 RR 728 Weight Percentage 50.3 Front Rear 49.7.
I'm gonna do a little of adjustment and see if i can get it a little closer and then if the weather holds out go test it.
