 Post subject: Pro Brake
 Post Posted: Sun Sep 20, 2009 5:03 pm
What all is involved going from a sportsman brake to a pro brake in a glide? Just valve body and solinoid, right?
How much real world RT difference have some of you seen making this swap?
Gotta get off the line on this .400 Pro Tree in these index classes!
 Post subject: Re: Pro Brake
 Post Posted: Sun Sep 20, 2009 5:47 pm
Your going to have to pull the trans to make another fluid dump for the reverse.
It's not to involved but it will have to come apart and it is quicker how much not real sure......
The hole need to be in the trans case..
 Post Posted: Sun Sep 20, 2009 9:55 pm
A pro brake can be built to work without the case mods used on a double dump as long as the reverse feed hole in the case is opened up larger than stock, not quite as fast but real close. Not sure who makes them now, been building my own for a long time.
 Post Posted: Mon Sep 21, 2009 6:17 am
Well, if that's the case it will just have to wait till its next freshen up. I come damn near to getting rid of this car everytime I have to jerk the motor or tranny out of it [-( . I can promise you any future car I have will be a tube frame with a removable tunnel, but that's a whole 'nother issue. :-({|=
 Post Posted: Mon Sep 21, 2009 8:49 am
Just wondering here, why would you switch from the normal brake to a pro brake ?
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
Fleenor Racing Glides
"get one before one gets you"
 Post Posted: Mon Sep 21, 2009 10:30 am
Dave I think he's looking for some more car RT so it can get a better light...I would just try a smaller tire and crank up the starting line RPM but maybe he has tried that already...
 Post Posted: Mon Sep 21, 2009 10:46 am
thanks for the reply
I have switched from a standard coan brake to a pro brake 3 different times now, and recently just went back to a std brake again. Delay never changes in mine, thats why I asked
David Lanning
IHRA NHRA 387B
 Post Posted: Mon Sep 21, 2009 9:12 pm
Try a hipster brake. They're not a double passage set up. Read the instructions on their site..
 Post Posted: Mon Sep 21, 2009 9:42 pm
Pro brake is a little quicker on mine but I'm not exactly sure how much.
 Post Posted: Sun Oct 11, 2009 8:49 pm
Tanner,
I know you don't want to pull the tranny again, mine stinks as well, but when I went to the bullet proof stuff(Dedenbear/Reid) trans case with roller tail housing, everything swapped over and I use a ATI solenoid with an ATI brake, and the Reid housing has an adjustable trans brake relase knob, so you can adjust it. Mine is on full GO, and I tend to redlight a little :- but if you want to spend the money, or already have a Reid case, look into this from ATI, I have had flawless fun so far with my trans stuff, Knock on wood =; Just a thought, not intending to make you spend money on Reid/Dedenbear stuff, it just works for me and I had 3 perfect lights last year, that's 3 (.000's) \:D/ \:D/ but then some reds too :-& live and die by the trans right? Good luck and let us know when you do.
