 Post subject: converter
 Post Posted: Fri May 22, 2009 7:34 pm
How does one figure out what converter is best for your application, With out dynoing your motor to get max tq at a given rpm. Will the logger help in this???
 Post subject: Re: converter
 Post Posted: Fri May 22, 2009 8:23 pm
A dyno is best, usually I can figure close on a SBC by the combination of parts. What are you looking for?
 Post Posted: Fri May 22, 2009 8:33 pm
Barry, I think you could get a ball park figure. My converter guy can take your set up info, what you want to achieve and get you pretty close.
http://bradcoengineering.com/
Wouldn't data info be influenced by set up and track conditions?
 Post Posted: Sat May 23, 2009 6:33 am
Most can tell ya what should be close by CI, parts in it, weight of car, gear ratio
Tell them you want it a little on the loose side also ;-)
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
Fleenor Racing Glides
"get one before one gets you"
