 Post subject: Tire wrinkle?
 Post Posted: Tue May 19, 2009 6:41 am
Here are some pictures from Sunday does the air pressure look good? Are there enough wrinkle?
http://www.photoreflect.com/pr3/orderpa ... 433&po=433
http://www.photoreflect.com/pr3/orderpa ... 434&po=434
http://www.photoreflect.com/pr3/orderpa ... 531&po=531
http://www.photoreflect.com/pr3/orderpa ... 621&po=621
And then some day
http://www.photoreflect.com/pr3/orderpa ... 620&po=620
 Post subject: Re: Tire wrinkle?
 Post Posted: Tue May 19, 2009 6:55 am
Steve, from what I have learned it's not how much the sidewall is wrinkling it's more how much of the tire patch is wrinkling O:) O:)
 Post Posted: Tue May 19, 2009 7:06 am
OK explain that one please :-s :-k
 Post Posted: Tue May 19, 2009 7:11 am
Ok, I'll try...........If you look at the tire patch just above where it is in contact with the track it should be distorted a few inches in from the side wall....I think I have a picture of my Vega with it showing what Im talking about...
You have Morgans book??? It's in there somewhere I think......
 Post Posted: Tue May 19, 2009 8:07 am
I think I know what you are talking about. Some cars I see leave kind of leave a pattern. I see some cars that leave a pattern like I call a paddle. I guess it is from wadding the tires.
 Post Posted: Wed May 20, 2009 4:56 pm
 Post Posted: Wed May 20, 2009 5:01 pm
O:) O:)
 Post Posted: Thu Aug 06, 2009 6:53 pm
Scott,
Is the page you posted above from a book or magazine? Is something that is available?
Thanks,
Greg
 Post Posted: Sat Aug 08, 2009 9:38 am
According to what I saw last night, at 10 psig I'm still TOO LOW! And Scott, 8.5 lbs DIDN'T WORK.
It's looking like I need to go back to where I was two years ago as everything I've done to the car has slowed it down. Best it ran last night was a 5.67 on a track that I've run 5.40s on. You wouldn't believe the engine and driveshaft RPM graphs even on that best pass! Out of 5 passes, I only got down the track twice! Had to abort the first three runs, two with 8.5lbs and one at 10.5lbs. Last two passes were at 10psig but it was still a dog! 1.30 something short times ain't gonna get it! Hell, the Studebaker @ 3500lbs would do that good with a pump gas engine and a 150 shot of juice!
