 Post subject: Confused again??!!
 Post Posted: Tue May 12, 2009 10:45 am
We have solid motor mounts and a urathane trans mount. Several people have been telling me to go solid all the way around. I'm sure this has been covered before. I can't run a mid plate in NMC so that is out of the question. The car doesn't twist like it used too.
 Post subject: Re: Confused again??!!
 Post Posted: Tue May 12, 2009 10:57 am
Don't. Some get away with it, but if you have any twist in the chassis you will break something, usually a bell housing.
 Post Posted: Tue May 12, 2009 5:21 pm
Steve I would try a stock GM trans mount and just keep an eye on it....You also may want to get a set of later gm mounts for the engine as they have stops on them but I don't think they will last to long. Or just replace the case every few weekends O:) O:) ......I have seen ultra bells crack :-s :-s
 Post Posted: Tue May 12, 2009 5:55 pm
Thanks guys. we all seem to agree solid motor , rubber trans. =; I still think I had it in a bind when I put the motor in. Thanks again.
 Post Posted: Tue May 12, 2009 6:24 pm
I did something years ago on my Chevelle, I used the thin "Plumbers Tape", the metal strap with holes around the mount and ran a bolt horizontally through the steel. Still allowed flex but kept it from separating too much.
