 Post Posted: Wed Apr 15, 2009 6:46 am
Greetings All
i am looking for some info in relation to the correct front wheel bearings for my car
it has a Lamb struts ( Anglia ) & i have just purchased a new set of front wheels ( Alumastar 788-15000 ) Anglia
the issue i have is Lamb list "SPECIAL" bearings for this application
the bearings that come with the new wheels are as follows
Inner Race: 4T - 07204 - NTN
Inner Bearing: 07097-544
Outer Race: 03162 HP
Outer Bearing: 03062
Seal is Timken boxed with the part number of 471795 however the seal is marked "NOK AD7127E"
what i need to know is, Do i need to buy
A: The Lamb "Special" set
B: Use what i have been supplied with the wheels
I have heard that i may need to use
C: 07098 Bearing
D: C-R (Chicago Rawhide) 12565 SEAL
regards
rod
The older I get the better I was
 Post Posted: Wed Apr 15, 2009 10:48 am
I was led to beleive Lamb and Strange spindle are bigger than Anglia. Anglia is about 5/8, I think Lamb are nearer 1in.
 Post Posted: Wed Apr 15, 2009 3:58 pm
I have 1 new set for one side of a strange setup. I will measure them after work and let you know the size. Free if you can use them. I have no need for them. I do know they will not work on my anglia spindles.
 Post Posted: Thu Apr 16, 2009 3:29 am
thanks for that Doug
but my car has Anglia size stubs on it
the struts that i run are manufactured by Lamb
i guess i will have to pull my old ones down & see if i can find some part numbers on the bearings ect, i just thought that somebody may of had the part numbers handy
thanks again
regards
rod
 Post Posted: Thu Apr 16, 2009 6:22 pm
Hey rodrocket, are you going to try the ceramic bearings? Heard they were the best...
 Post Posted: Thu Apr 16, 2009 10:05 pm
i didnt even give thre ceramic bearings a thought, to be honest i thought they were only run in the Dewco centres
regards
rod
 Post Posted: Sat Apr 18, 2009 8:24 pm
i guess nobody runs Lamb struts with an Anglia spindle in here
regards
rod
 Post Posted: Sat Apr 18, 2009 11:43 pm
Sorry I could not be of better help. Almost all my junk is home made and southern enginered.
