 Post subject: Trans relief spring
 Post Posted: Fri Feb 20, 2009 8:34 pm
Would there be a problem with shimming the Pressure relief spring to raise the
pressure??? Anyone??? Ken????
 Post subject: Re: Trans relief spring
 Post Posted: Fri Feb 20, 2009 9:11 pm
Glide? Brake? You can get heavier springs from most of the trans companies, TSR Racing is a good source. And as long as it doesn't interfere with the regulator and boost valves, shims are OK.
