 Post subject: what gears to use
 Post Posted: Fri Jan 02, 2009 1:32 pm
i have 4;88 gears now and been told i'm to low gears for blower engine.my first blower engine.will be doing some controled gurge racing at car shows and cruises[at air ports NOT ON STREET]1/8th mile and some less.but also whant to do 1/4 at the drag strips..what gear raito should i run or can i leave what i have in car now?still building car so don't have rpm range on engine just the specs i have below..also trying to get converter built for car and they want rear gear raito before converter can be built.. what i'm trying to build is a strong/easy in the 8's street legal car
CAR BUILD SPECS
540bbc/11.8 comp pistons/heads will be done by curtis[pro valve job/c-n-c ported and flowed/i think he said around 445 cc flow but don't remember if that is before or after he works on them]they are brodix 2-plus heads/roller cam with 736 lift 116 LC ;871 stage 4 blower/aly injection bird catcher w/modified square doors]mallory super maglll ign.//trans is PG with 10 disc high gear-stright cut 1;80 planitary-trans brake/4;88 rear gears/spool/32.14.5 slicks/
62 nova wagon built into a 2 door seden delivery with glass doors/front end/guted tail gate-full chassis car with M/S cage[hope to certifie to 7;50/has steel firewall and steel floor with middle trans tunnel and drive line tunnel aluminum/christ alston a-arm front end/ladder bar rear/
 Post Posted: Fri Jan 02, 2009 1:54 pm
I would think a 4.11 or a 4.30 gear would be good with that big of a motor... :-k
What trans???
 Post Posted: Fri Jan 02, 2009 4:23 pm
What trans???
it is a PG built by PRINCE RACING TRANS..has a  1;80 planatery.10 disc high gear/trans brake
ready to get a converter and they need to know what gear before building converter.have 4;88 in rear now but finding out i'm to low gear for my engine.cheaper change gears then having wrong verter.
 Post Posted: Fri Jan 02, 2009 4:34 pm
I'm with Barry on the rear gear.  With all that blower torque you're not gonna need that deep a gear.  4:11 sound about right from here, especially iff'in you're running some big meats on the rear.
 Post Posted: Fri Jan 02, 2009 4:46 pm
Whats it gonna weigh?
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Fri Jan 02, 2009 4:55 pm
don't know weight yet..it was a 4 door wagon[64 nova] but made into a 2 door seden delivery/has glass doors/glass front end/glass tail gate/lexan windshield and lexan door windows/glass roll pans instead of bumpers/aluminum floor&interior/16 ga. steel fabacater firewall/2x3 chassis with mild steel cage/alston tube a-arms.
any extimates on weight would be good;;
 Post Posted: Fri Jan 02, 2009 5:03 pm
Think I might even go for a 3.89 with a blower, they just love pulling hard..
with a 32 inch tire too.
Sam
 Post Posted: Fri Jan 02, 2009 5:41 pm
Ok we are going to need some pictures  =;  =;
 Post Posted: Sat Jan 03, 2009 7:08 am
I have seen a 4 door Chevy II wagon made into a 2 door. Glass doors and front end. It really looked nice. I always wanted one.
I asked about weight because I am always measuring my combo against what others are running. I have been considering a gear change.
-- Albert Einstein
