Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Converter ??
 Post Posted: Mon Dec 22, 2008 3:10 pm
I have a TCI 8" converter that has a glide spline. It need to get rebuilt as It has 250+ runs on it but was wondering if it can be changed to a turbo spline??? Thanks
 Post Posted: Mon Dec 22, 2008 3:21 pm
Barry call Brian Robinson @ BTE 800-626-1828.  He is the guy that Scott and I deal with there and he can probably tell ya.  I got no clue on this one.
 Post Posted: Mon Dec 22, 2008 3:24 pm
Sounds like a good idea :-s ..
 Post Posted: Mon Dec 22, 2008 3:26 pm
I read on computer somewhere the other day that someone was advertising convertors and in the ad it said that the spline could be changed when you bought it.  Don't recall who it was though.  I've been looking at so many different things the past few days.
U can step on the brake,
U can step on the gas,
But step on ur crank,
Ur gonna get passed!
 Post Posted: Mon Dec 22, 2008 4:58 pm
I think going from glide to turbo should not be an issue if they are cutting it open anyway.
 Post Posted: Mon Dec 22, 2008 5:48 pm
Thanks Guys!!
 Post Posted: Mon Dec 22, 2008 6:15 pm
Hey Barry, you could also try Select Proformance I'm sure they could tell you. =;
 Post Posted: Mon Dec 22, 2008 10:52 pm
I believe the input shaft is splined to the stator, would be no big deal either way. Usually a Cut and Clean is aroung $100 Not too bad but I am not sure about BTE's prices on that.
 Post subject: 2 birds, one stone
 Post Posted: Mon Dec 22, 2008 11:47 pm
Yeah, that thingy inside the convertor has to have the same spline as the shaft, so yes  to that question and yes again since they are cutting it open they just change that stator/sprag thingy or whatever they call it, and you get to buy another new shaft too =;  =;  =;
 Post Posted: Tue Dec 23, 2008 12:04 am
Actually the input shaft is splined to the turbine, the stator to the stator support.
 Post subject: Re: Converter ??
 Post Posted: Tue Dec 23, 2008 5:25 pm
        I understand your desire to change it to a turbo spline, but you are saying it needs to be gone through because of 250 passes? If so mine is shot. I do that every season.
 Post Posted: Tue Dec 23, 2008 5:37 pm
They say it should be done at that point O:) ...I did use one till it had over 350 passes on it and the sprag exploded so since then I try to get them serviced every 250 to 300 passes
 Post Posted: Tue Dec 23, 2008 6:50 pm
That's interesting, I probably have over 500 passes on mine, maybe more. Something else to think about I guess.
 Post Posted: Tue Dec 23, 2008 8:58 pm
[-o<  [-o<  [-o<  [-o<  =;
 Post Posted: Wed Dec 24, 2008 1:35 am
OK I haven't trolled in a while...mine doesn't have a sprag so it can't explode. =;
George
