 Post Posted: Wed Nov 19, 2008 7:30 pm
Can anyone explain how the adjustable transbrake release is sealed on these case?
Thanks,
Greg
 Post Posted: Thu Nov 20, 2008 9:53 am
They use an o-ring.    Matt
http://www.sommersracing.net
 Post Posted: Thu Nov 20, 2008 11:12 am
Is the grove for the oring cut into the case or is it on the adjusting screw?
Thanks,
Greg
 Post Posted: Thu Nov 20, 2008 11:28 am
The groove is on the adjusting bolt.
 Post Posted: Thu Nov 20, 2008 2:14 pm
Have you had any problems with the Reid case itself ? I switched from stock case and made no other changes and now this thing is hot all the time. Had it looked at by a good trans guy said there is a passage in the case that isnt drilled all the way like it should be, have you seen this ?
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
Fleenor Racing Glides
"get one before one gets you"
 Post Posted: Thu Nov 20, 2008 4:52 pm
Matt,
Thanks for the info.
Greg
 Post Posted: Fri Nov 21, 2008 7:07 am
David, Tell us more about your un-drilled passage please.
Thanks, Mark
 Post Posted: Fri Nov 21, 2008 7:17 am
Our JW Ultra case leaked no matter what we did. A 1/4" NPT tap and 1/4" NPT plug fixed it.  :-$
 Post Posted: Fri Nov 21, 2008 1:48 pm
I'm following this thread pretty close as I am thinking about buying a Dedenbear/Reid case this winter. In my altered I am fully exposed to the transmission even with a shield.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Mon Nov 24, 2008 11:13 am
I have not had any over heating do to the cases.  What are the temps you are seeing?
 Post Posted: Mon Nov 24, 2008 10:12 pm
I have not had any over heating do to the cases.  What are the temps you are seeing?[/quote]
Before it got new case 150-160 max all day  new case now 200-210 in 2 passes.  Trans guy is as good as it gets he is baffeled as I am, we went ahead and put a new good pump in it (had a blueprinted stock in it before) same problem. Raced it a few weeks took it back out, it has never everything but gear set now and still same issue. Leaned towards converter, I have 2 spares put both in and both same issue. Gave converter to a buddy to try never got over 150 with his setup.  Several local trans guys are lost on what to fix now. Only thing we havent changed now is the cooler and back to a different case.  Of course this was not a issue before the case was changed ?? very confusing
David Lanning
IHRA NHRA 387B
 Post Posted: Mon Nov 24, 2008 10:16 pm
I'm logging trans temp and you guys would s**t if you saw what I've seen on that graph! ;-)
 Post Posted: Mon Nov 24, 2008 10:33 pm
Ok let's see it =;
 Post Posted: Tue Nov 25, 2008 7:35 am
I run a Dedenbear case and it's great, had no real issues with it.
 Post Posted: Tue Nov 25, 2008 8:14 am
That is a Reid case =; Right?? :-k
