 Post Posted: Wed Nov 12, 2008 5:36 am
greetings all
i am after some info on the Koni's that are in the back of my car & hope somebody hear can shed some light on them
as the car is at work & i am home or a couple of days i am unable to remove them the measure up what i alread have
i have the part numbers ect from the body of the shock but carnt seem to find any measurments of them on the net
the details that i know of that are on the body are as follows
8211 - 1126
8703 SPA
1 ? 4-496
the 8211 i know is a steel-bodied, externally double-adjustable
as for the rest of the numbers i carnt find any info & am hopeing that somebody here may know or be able to point me in the general direction
I have an oppertunity to purchase a brand new pair of Koni Electric adjustable shock & if its a straight foward change i will buy them but if i have to make modifications to fit them well then i will stick with what i have
regards
rod
 Post Posted: Wed Nov 12, 2008 9:05 pm
Rod I don't think they even make them anymore O:) ..I had a pair of them in my Vega and sent them back for a rebuild and they could not repair or rebuild them O:)  O:) ..That kind of pi$$ed me off as I had to pay for the shipping both ways for something they should have told me they can't rebuild anymore [-(  [-( ....SOOOOOOO Im done with them [-o<  =;
 Post Posted: Thu Nov 13, 2008 4:40 am
thanks for that Barry
it was only the measurements that i was looking for as i was to lazy to go into work & pull one from the car the measure it up
the weather has turned to $**t here so i may go in on the weekend & measure it up as i have an oppertunity to purchase an electric pair for the right money  ;-)  & if its a straight foward bolt in job then i will buy them but if i have to stuff around to make them fit then i will make do with what i have
thanks again
regards
rod
 Post Posted: Thu Nov 13, 2008 6:53 am
Rod,
I don't see alot of guys using Koni's anymore.  Guys with money use Strange and it you have alot of money then Stantuff is on there..
