 Post subject: BRAKES
 Post Posted: Tue Jun 06, 2006 6:55 pm
i need help...i put front brakes on my wifes explorer sunday and now it has no brakes unless ya pump them like there is air in them...bled them amd still acts like its got air so went and bought a new master cylinder bled it bled all the brakes and even adjusted the back ones up and still acts like its got air in them any ideas
 Post Posted: Tue Jun 06, 2006 7:48 pm
anybody?
 Post Posted: Tue Jun 06, 2006 7:53 pm
what vehicle are you talking about?
 Post Posted: Tue Jun 06, 2006 8:02 pm
ford explorer
 Post Posted: Tue Jun 06, 2006 8:03 pm
they worked fine with the old brakes they just made noise when you put the brakes on to stop
 Post Posted: Tue Jun 06, 2006 9:39 pm
If you happened to leave an open hose where it could drain all the fluid from the lines you may want to start at mastercylinder them proporsing valve then go to bleeding wheel cylinders. Just pump up and crack lines they sometimes want to keep that air there even when your not getting it out of the bleed valves.
 Post Posted: Wed Jun 07, 2006 2:06 am
Avery, did you open the bleeders when you pushed the caliper pistons back? If not there was no reason for the brakes to have air in them to start with. You need to make sure the pads and hardware was installed correctly. Sometimes when something is out of place it pushes the caliper back in when you let off the brake.
 Post Posted: Wed Jun 07, 2006 5:32 am
no i didnt open any bleeders just collapsed the calipers and put the pads on..when you bleed the master cylinder should you have the same amount of pressure coming out of each line?because the front line which is going to the back wheels just barely pushes any fluid out...but the rear line which is going to the front blows the $**t out pretty good...guys thanks for any help yall can give and have given
 Post Posted: Wed Jun 07, 2006 3:59 pm
hey guys just got back from taking the new master off and taking it back and getting another.bench bled it and then went ahead and bled the rest of the brakes.work fine now thanks for any info yall gave
