 Post subject: springs
 Post Posted: Thu Jun 01, 2006 7:17 pm
would the spring lenght be the same for a 2 door and a 4 door 73 nova with mono leaf springs in the rear am trying to figure out what to order and not sure what to do i would imagine the spring length is the same not sure though
 Post Posted: Thu Jun 01, 2006 7:24 pm
Yes they are. Will also be the same as an early camaro. =;
 Post Posted: Thu Jun 01, 2006 7:37 pm
thanks for the wuik reply stroker and i didnt know that the camaro was the same oh well just trying to put together and order here so i can get this beast on the rroad by the end of the summer im going to order all of the stuffi can think of at once to just get it done wiht
 Post Posted: Thu Jun 01, 2006 7:38 pm
oh another thing what about sub frame conectors oviously they have to be longer dont they any place i can get some for a 4 door
 Post Posted: Thu Jun 01, 2006 7:58 pm
Check your wheelbase. It may be the same as a 2 door, if not you may have to make them-2 by 3 tubing or similar. Hope this helps.
Greg
 Post Posted: Fri Jun 02, 2006 12:17 am
If you do make your own , overlapp front and back as far as you can and plug weld them as well as just the end seam. This spreads load on orignal stubbs.
 Post Posted: Fri Jun 02, 2006 7:29 pm
oh well i want plannig on making my own dont think i could by the material and come out on top as if i just boughtthem if i found someone that carries them
