 Post Posted: Wed May 17, 2006 10:58 am
Hi you guys. Does anyone know what the bolts fastening the converter to the flexplate should be torqued to? They are 7/16, grade 8, on my AMC. I love this forum, I cant believe you pulled it off. Good ideas usually just stay ideas.
Ty
 Post Posted: Wed May 17, 2006 11:26 am
Ty
I have never torqued them down myself just went a tad past " ummmph " I would guess 50-60 ft. lbs
edit: I also apply some red loctite to the fastners
 Post Posted: Wed May 17, 2006 11:41 am
I go real tight with everything..I go almost as tight as I can get with a wrench..one handed..
 Post Posted: Wed May 17, 2006 2:49 pm
I never used a torque wrench on those either. Like Duane I do use locktite though.
 Post Posted: Wed May 17, 2006 3:38 pm
Ditto to tight...
anyone know the torque spec flex plate to crank ??
in fact a full set of torque specs for a bbc would be handy..
TYVM
Sam
 Post Posted: Wed May 17, 2006 4:55 pm
Sam ... here are the specs for the factory stock fastners. Anything other than stock you need to check with the manufacter. I have some specs for ARP stuff around somewhere but would have to search for it. I think they have a list on their website.
Main Cap Bolts ... 110 ft. lbs
Rod Bolts ............ 50
Head Bolts ........... 80
Balancer Bolt ....... 85
Flexplate Bolts ...... 65
Intake Manifold ..... 30
Exhaust Manifolds .. 20
 Post subject: torque specs.
 Post Posted: Wed May 17, 2006 10:27 pm
My old book shows
2 bolt main caps 95 lb ft
4 bolt 105 lb ft
flywheel to crank 60 lb ft
clean lightly lubed threads
 Post Posted: Thu May 18, 2006 5:47 am
all single seal rear mains should be tourqued to factory spec. over tourquing can cause seal to leak or uneven tourque. \:D/ \:D/ \:D/ \:D/
