 Post subject: 14 bolt
 Post Posted: Thu May 04, 2006 10:33 am
should i put a 14 bolt in the rear of my 73 nova 4 door what is involved in the sawp do i have to change anything im assuming i will have to please help i found one for a good deal and was juts curious im going to have this car being strictly drag car so im looking ofr somthing with some strenght
 Post Posted: Thu May 04, 2006 10:54 am
your factory 10 bolt will do just fine...good full spool,good gears and a good set of axles.and a rear end girdle....will hold plenty of power...put 33 splinesin it and you can use c-clip elimnators in it or what I would do is to weld on a big ford ends and have bolt in axles...much stronger ..
 Post Posted: Thu May 04, 2006 11:37 am
what brand axles do you recomend i will be going wiht yucon gear for the gears
 Post Posted: Thu May 04, 2006 11:42 am
Well,,I have used Moser with good results..there are others...strange,,mark wiliams ,etc....strange s/s axles prob work well..not to bad on the price neither....a good strange spool..etc....richmond(8620) street gears would be a good choice..
