 Post Posted: Mon Apr 24, 2006 9:34 pm
Hey Steve, Glad your here and welcome. Whats your opion on Hyd fluid in a racing glide?? Ken has ran it in a digger for a season and I don't think he had any problems. I can't remember the web sight but there was a tech art. on this subject,, someone remember:-k :-k Barry
 Post Posted: Mon Apr 24, 2006 10:03 pm
Got it in this new tranny I built for the Camaro too! Was thinking about putting it in my Chevy truck TH700r4 as well.
 Post Posted: Mon Apr 24, 2006 11:02 pm
hydraulic oil works in trannies????...isnt that similar to the old style ATF type "F" fluid?
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Tue Apr 25, 2006 8:30 am
http://www.mrwendellstds.com/tech.htm
That's the link to the guy's site that really likes the tractor fluid. Interesting read. I bought a 5 gallon bucket of the tractor fluid from Tractor Supply near here for $44. That's 20 quarts of fluid which means it's $2.20 a quart. I'll bet Moble1 is at least $5 a quart.
That tractor fluid has a funny smell to it. It almost smells like a synthetic fluid to me.
Anywho, after I started running the stuff last year I started talking to other racers about it and found a good many of them were already using it? Crap, and I thought I knew something they didn't? O:) Oh well, I got fooled again I guess.
 Post Posted: Tue Apr 25, 2006 2:40 pm
thats hard to believe....im almost afraid to use tractor hydraulic fluid in my tranny.....i dont think i could bring myself to do it
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Mon May 01, 2006 11:04 pm
why not tractors have trannys to hyd.oil is made from a 150 base neutral stock with heat and wear additive in it for pres. and heat trans fliud is 10 w motor oil with red dye in it worked 7 years at a oil company that makes motor oil hyd, oil cleaners and all oils for steel mills vulcan oil and chemical .cincinnati they also blend a lot of syn.oils used to do a lot for cat. and cummins probaly should not of said that they labeled every thing with cats and cummins labels for them oh well any way you want have any problems with hyd,oil in your trans aw 32 will do just fine .
 Post Posted: Tue May 02, 2006 6:36 am
the twin disc trans in boats use straight 30w oil. mostly coupled up to diesels. tony.
