 Post subject: size rearend
 Post Posted: Sat Apr 22, 2006 1:55 am
does anyone know what size rearend is in a s-10 blazer?is it 7.5
 Post Posted: Sun Apr 23, 2006 7:53 am
I believe you are correct \:D/
 Post Posted: Sun Apr 23, 2006 9:25 am
sounds right
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Sun Apr 23, 2006 9:35 am
so i got a junk rearend to start with..go figure
 Post Posted: Mon Apr 24, 2006 3:05 pm
Yea it's either a 7.5 or a 7.58 won't handle much.. [-(
 Post Posted: Mon Apr 24, 2006 5:29 pm
you run a s-10 dont ya?do you know what rearend will fit up under it without having one cut down?that will handle a few horse?
 Post Posted: Mon Apr 24, 2006 5:37 pm
Do some real good measuring. I think a s-10 is shorter than the blazer. =;
 Post Posted: Mon Apr 24, 2006 6:27 pm
im just wondering if a 8.8 out of a gt will fit?are does somebody know if there is a 9 inch with the same width are big 10 12 bolt?
 Post Posted: Mon Apr 24, 2006 11:04 pm
i think a Ford 9" should fit under there.....just do real good measuring as said above
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Tue May 09, 2006 2:28 pm
find a good deal on a ford 9" or like me a mopar and then have it cut down and new axles built. I have only 1300 in my mopar 8 3/4 and it is 38 1/2" wide my stock rearend out in garage, that I cant give away is 54" wide I sent my mopar rear to dutchman in portland or. and they narrowed it,built billet axles,installed drain and fill and put big ford ends on all for a little over $700
http://www.s10dragracer.com/
 Post Posted: Tue May 09, 2006 4:24 pm
I believe a stock rear end in an S10 is like 49" Wide I have a 56" wide rearend in mine but my wheels offset most of it, they stick out a tad and I am planning on taking care of that this fall.
 Post Posted: Tue May 09, 2006 6:47 pm
my 83 blazers rear end is 54" wide from drum to drum, the new one is 38.5" wide from drum to drum \:D/ \:D/ \:D/
 Post Posted: Tue May 09, 2006 7:05 pm
is that backing plate to backing plate
 Post Posted: Tue May 09, 2006 9:07 pm
from what I am told, drum to drum is outside drum to outside drum or the distance between wheel hub to wheel hub :-$
 Post Posted: Wed May 10, 2006 8:50 am
I also read a article on a s10 site about a guy ,who swaped in a 8.8 ford out of a explorer it had posi and cost him $175 , it was out of a 92, and he said 95 and up had disc brakes, anyways dont know if that helps
