 Post Posted: Thu Apr 20, 2006 6:58 am
What is the best way to wire the Nitrous, so that when I let off the transbrake button the nitrous is engaged?.. :-s
 Post Posted: Thu Apr 20, 2006 9:32 am
Run the N2O system off of a WFO switch and have a relay control the power to the WFO switch.
Have a relay triggered by the t/brake open the N2O circuit when the t/brake is triggered and then close the N2O circuit when the t/brake is released.
I think it was mentioned that dedenbear had the wiring diagrams on their website if you need more info.
 Post Posted: Thu Apr 20, 2006 2:39 pm
...yeah...like Duane said a wide f**&^% open switch....no seriously he has the right information for ya...when you on the trans brake normally not fully on the gas....I don't know where you leave off the transbrake...but with the WOT switch when you stab it the NOS is there.... \:D/ \:D/
James
79 Z28 496 BBC....
 Post Posted: Fri Apr 21, 2006 9:26 am
I usually leave off full throttle off the brake...That was my worry,I don't want to activate the Nitrous while on the brake..
 Post Posted: Fri Apr 21, 2006 9:34 am
this is where using a relay comes into play
at full throttle w/ brake on N2O is off
release the t/brake .. N2O is activated
 Post Posted: Mon Apr 24, 2006 3:13 pm
Thanks alot got it all right and proper I printed off Dedenbear's diagram
and followed it, checked it it was dead on. You can't even feel it come in it's there as soon as I release the brake =D> Just feels like a stronger motor! Thanks for the Help!
 Post Posted: Mon Apr 24, 2006 9:52 pm
It is great! That is the way it should be. I really like to be of help to someone and get help when needed. =D> =D>
