 Post subject: Distributor
 Post Posted: Mon Jul 25, 2011 6:13 pm
Hey guys I am putting a MSD crank trigger on my 55 and dont want to buy a MSD dist. I know you can make one but can i just leave the one that is in there and not plug it up. Thanks KennyMac #-o
 Post subject: Re: Distributor
 Post Posted: Mon Jul 25, 2011 6:21 pm
Yes, you will have to make sure the rotor phase is correct.
 Post Posted: Mon Jul 25, 2011 7:50 pm
Also you need to lock the advance if it has one :-
 Post Posted: Mon Jul 25, 2011 8:18 pm
Thanks guys it is a MSD pro-billet distributor.
 Post Posted: Mon Jul 25, 2011 8:24 pm
I think that dist has a lock built in it :-k Kenny
 Post Posted: Mon Jul 25, 2011 10:56 pm
Yeah, you take it apart and you can turn the top piece on the shaft 180* and it's locked. Drill a 3/16 hole between #1 and the coil wire terminal and use that to "phase" the distributor. Oh, and some ppl use a timing light to do this but I just usually set the timing mark on however much advance I have in the crank trigger then phase the distributor by looking in that aformentioned hole to make sure it's pointed at #1
 Post Posted: Tue Jul 26, 2011 4:56 am
You can drill the hole in the cap for phase on any wire as long asou use that wire to phase it.. On my Vega
it was hard to see #1 so I did it on #6 instead =; .......
 Post Posted: Wed Jul 27, 2011 6:33 pm
Thanks for every bodys help \:D/
