 Post Posted: Thu Sep 23, 2010 6:09 pm
adding coil packs to motec control system.. made up spacers, drilled and tapped valve covers to mount coils..
Andy was up in the boat setting up the wiring most of today and will have to finish tomorrow, I also have to make up the mount for the crank trigger..will be doing that 1st thing in the morning...
 Post Posted: Fri Sep 24, 2010 5:10 am
Looks good tony....How are going to make sure that the nuts don't fall off.. #-o
 Post Posted: Fri Sep 24, 2010 5:44 am
it is a nuetered version... =; the valve covers are cast aluminum so i drilled and tapped them used red loctite on threads..
 Post Posted: Fri Sep 24, 2010 6:10 pm
finished.. \:D/ \:D/
 Post Posted: Fri Sep 24, 2010 7:10 pm
What you can do now is run some dummy wires from the redundant dizzy into a black box and then into the air cleaner. That will get everyone guessing and start a craze.
 Post Posted: Sun Sep 26, 2010 5:55 pm
=; that would be a neat idea, not my boat though this was a job for a customer.. i could email him the idea though.. ;-)
 Post Posted: Sun Sep 26, 2010 6:49 pm
Dayum, I thought you had switched to a Big Block!!! =;
 Post Posted: Sun Sep 26, 2010 9:26 pm
