 Post subject: Starter Circuit
 Post Posted: Thu Aug 05, 2010 11:56 am
Should I use a relay on the starter solenoid circuit, or can the starter button handle the draw?
Also what gauge wire should I use?
Thanks guys
Oh, I already am grey
 Post subject: Re: Starter Circuit
 Post Posted: Thu Aug 05, 2010 8:34 pm
Hey Mike, sorry to take so long on a reply but I'm retired and have no time! O:)
Ok, no more BS.
I've built two cars from scratch and bought 3 others built by someone else and all used the regular push button starter button deal. I know that some use relays but I've never liked those as I figure that's just something else to go wrong on race day that I don't want to have to troubleshoot at the track.
So long story short is I use the regular high current push button start buttons on everything I've built and or bought (5 cars) with zero problems.
As far as wire size goes, I used 14ga wire on all the ones I built from scratch and the cars that I bought also had 14 ga wire on them also.
But whatever you use, make sure you put a fuse in that circuit! And always carry some spares in the car! ;-)
You're mileage may vary!
 Post Posted: Thu Aug 05, 2010 10:28 pm
I don't have a relay on mine either and that's how both of my cars were set up. As long as it's a good switch and heavy enough wire I don't think you need a relay. I use a mini starter with an integral solenoid and would assume you have something similar. The only application I have ever seen where a relay was needed was on a stock GM application where the wiring and switch was getting old enough that it needed the extra help.
 Post Posted: Fri Aug 06, 2010 7:32 am
That makes things simpler... Was planning on using #12 gauge, so can't go wrong there
