backfeeding alternator
http://motorsportsvillage.com/forum/viewtopic.php?f=7&t=7363
Author:  zephyrc [ Sun Jun 27, 2010 6:57 am ]
Post subject:  backfeeding alternator
i found today that if i switch the motor off it continues to run until it runs out of fuel,, is it possible that the alternator is backfeeding the ignition system.. if i disconnect the alt light wire at the alternator motor stops as soon as i turn it off, also if i remove the bulb it stops when turned off.. when i turn it off the warning light comes on and stays on until motor runs out off fuel..alternator is a powermaster 7294
Author:  Ken0069 [ Sun Jun 27, 2010 8:08 am ]
Post subject:  Re: backfeeding alternator
You need to add a diode to your dash light/exciter circuit to prevent current feedback to the MSD. The user manual from MSD has a section in it to deal with this issue.
Author:  rick360 [ Sun Jun 27, 2010 8:59 am ]
When you turn off what switch? Main battery disconnect or the ignition switch?
Did you change something or when/how did this happen.
Author:  zephyrc [ Sun Jun 27, 2010 11:23 am ]
rick,, it is happening when i turn of the ignition switch,,, my ign live is fed from a fuse board to all ign live parts including the alt light and oil pressure light.. its been that way for 3 years or more, but only now has it started back feeding.. have i wired the car incorrectly or is the alternator faulty
Author:  zephyrc [ Sun Jun 27, 2010 11:52 am ]
alternator has 3 wire connectios,,. main power feed to battery,,, alternator warning light and another terminal which i am told is to sense battery voltage
Author:  rick360 [ Sun Jun 27, 2010 1:34 pm ]
It's strange that it did work and doesn't now, but I'd look into the MSD info like Ken suggested. You are definitely getting power back to your ignition from your alternator. A diode should prevent that. On 3-wire alts I always wired them as 2-wire using only the main large wire and a single wire from ignition with a diode between the terminals. I remember when the diode was backward the car wouldn't turn off.
Author:  zephyrc [ Sun Jun 27, 2010 5:08 pm ]
have ordered the diodes, will be a couple of days i guess, will fit one and let you know.. is this a fault in the alternator that has arisen..
Author:  Ken0069 [ Sun Jun 27, 2010 5:13 pm ]
Can't answer that but I run a 3 wire on both my cars. One has a 7AL and the other has a Digital 7 and both require that diode before they will shut off by the switch.
Author:  phillygoat [ Fri Jul 08, 2011 12:00 am ]
Just curious if the diode took care of it or was it something else?
PHILLYGOAT
Author:  morpheus [ Fri Jul 08, 2011 5:22 pm ]
I use a separate 150 amp circuit breaker in the feed line to the alternator. One click shuts the entire car down... no worries about something left on and draining battery dead.
Paid $15.00 for it, solid piece of equipment, gave me a 10% online order discount, the ride to NJ from Cali was $6.80.
Quality Power Auto, Inc., in Yucaipa, Ca. 92399.... 909-794-1600. Qualitypower@aol.com
CB-150 Circuit breaker-150 amp... was called a Scorpion IIRC.
