 Post subject: Wire gague
 Post Posted: Thu Dec 31, 2009 10:18 am
Would #4 AWG be sufficient to run from the battery to the starter? Its copper service entrance cable, and I have about 30' of the stuff. Or should I bite the bullet and use #1 AWG?
Mike
Oh, I already am grey
 Post subject: Re: Wire gague
 Post Posted: Thu Dec 31, 2009 10:40 am
Mike, I would not use that as the strands are heavy..Go to a welding supply house and get some welding cable...I used # 2 bends real easy and 25' roll is about 30 bucks if I remember correctly....Oh and it has about 800 strands...
 Post Posted: Thu Dec 31, 2009 11:17 am
Barry, never thought of that... There is a welding supply about a mile from me. Happy New Year!!!!
 Post Posted: Fri Jan 01, 2010 10:25 am
get the welding cable to starter use the 4 gauge for a ground to the motor area from the battery :)
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
Fleenor Racing Glides
"get one before one gets you"
 Post Posted: Mon Jan 04, 2010 10:00 pm
X2!!! House wiring, machine wire, etc belong in their perspective areas....not in race cars. Welding cable is definitely cable of choice....and remember, the grounds are just as important so the quality of cable you use is just as important. Save your service cable for your next panel upgrade or remodel =;
Jeff Brandenburg
 Post Posted: Tue Jan 05, 2010 12:56 pm
opps I didnt catch the service cable ... no doubt dont use it for ground either
David Lanning
IHRA NHRA 387B
 Post Posted: Mon Jan 18, 2010 7:42 am
Hey guys,
I have used 2ga in my chassis and have never had an issue, and I run it from the batt. to the kill switch and run one single wire up to my starter solenoid on the firewall, then on the other big post from the solenoid I run 2ga again down to my starter(1 wire deal, mini, CSR).
Barry, with your info you typed in here, is your (#2) the same as 2gauge? that I wrote down??? I wanna say it is :-k :-k
Is 2ga suffeciant? I am about to rewire this same area very soon, like within the next 3-4 weeks and if I need something different, now would be the time to change and get new pricing and availability. I have Terminal Supply right in my back yard and if I call ahead, they can have exactly what I need. Thanks and have a great season this year. =;
 Post Posted: Mon Jan 18, 2010 8:50 am
#2 same as 2 gauge....I would get rid of that sol on the firewall...
